2000 Cadillac Catera Transmission Oil & Filter
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, 2000 Cadillac Catera Transmission Oil & Filter in Past Cadillac Vehicle Discussion; Has any of my fellow cadillackians done there own Transmission fluid/filter exchange? If so how much fluid do you have ...
    destinyintllc is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Feb 2011
    40
    23
    If so how much fluid do you have to put in the pan before re-closing it?
    Thanx in advance
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    Re: 2000 Cadillac Catera Transmission Oil & Filter
    the transmission is a "fill untill" there is a fitting on theside you remove, then fill.. untill it overfills. I belive it is around 8 quarts.. I belive you have to run the car.. its kinda a pain.. you have to have the special type seringe to fill the tranny. there was a recent post on here about it.. look through the posts..
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    I just used a siphon pump / hand held pump with the passenger side of the car jacked up a little where I could hold my hand to the hose going into pan bolt opening. I then refilled it with fluid until it started to come out slowly.
    Feb 2011
    40
    23
    thanks guys it might be worth just letting the dealer do it. When is it recommended to do 125k?
    hgqguy's Avatar
    Nov 2009
    Rochester NY
    37
    449
    i replaced mine after I bought the car with 121K and I didnt have any issues. But it was clear it had been serviced before.
    Feb 2011
    40
    23
    thanks
  9. Remove Advertisements
