Help 2000 Catera no response to accelerator pedal HELP!!!
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Cadillac Catera and Cimarron Forum Discussion, Help 2000 Catera no response to accelerator pedal HELP!!! in Past Cadillac Vehicle Discussion; One day I went out started my car went to take off and it just started jumping and wasnt responding ...
    destinyintllc is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Feb 2011
    40
    23
    One day I went out started my car went to take off and it just started jumping and wasnt responding to the gas pedal. I checked and replaced the spark plugs, replaced the valve cover gaskets, and the throttle body and still did not fix the problem. Im stumped now. The computer isnt kicking back any codes except a broken tail light which I knew. I am thinking it has to be either the accelerator sensor or the computer. Any suggestions and does anyone know what the cigarette pack sized box is by the fuse box under the steering wheel? Any help is very appreciated I love this car!!!
    Feb 2011
    40
    23
    Re: Help 2000 Catera no response to accelerator pedal HELP!!!
    It seemed to happen soon after I slammed the reverse/brake light in the trunk and I forgot to mention the TC light is now on never was on before
    TitanCTS's Avatar
    TitanCTS is offline Cadillac Owners Fanatic
    Aug 2003
    Watertown, MA
    32
    199
    Is your throttle body plugged in?
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    slammed the reverse / brake light in the trunk? This does not makes sence to me...you shut the trunk hard?
    Your car is in power down mode. you said you changed the throttle body? did you have it reprogramed? If you change a throttle body It HAS TO BE REPROGRAMED.
    Sorry what yr? 99-00 I assume.. check the connectors to the throttle body.. see if there is any moisture.. corrosion.. clean it up.
    When my car did powerdwon mode the sport and tc light where on.
    Feb 2011
    40
    23
    Thanx for the response. Yes the throttle body is plugged in.......The lights that are on the trunk the covers are gone and didnt notice it hanging and closed the trunk. I changed the throttle body to try and fix the problem so that isnt whats causing it. Its a 2000 Catera 87k miles. I did notice one day that when I held the plug to the throttle body it seemed to idle a lil different. How do I get it out of power down mode?
    Feb 2011
    40
    23
    memphisrep is offline Cadillac Owners Member
    Automobile(s): '08 Esky
    Jan 2011
    37
    86
    Im no mechanic but I'd be inclined to say computer issue.I had a 1995 Nissan maxima that was having some erratic idle issues but not throwing any codes. I cleaned just about everything I could think of IACV and such,ignition coils but anyway went to a junkyard and lucked up on an ECU and that fixed my issue
    Feb 2011
    40
    23
    thanx for the heads up thats my next move getting the throttle body programed and the computer checked
    hgqguy's Avatar
    Nov 2009
    Rochester NY
    37
    449
    Must be done at GM dealer.. it touching the plug is making a differance then probly the problem was the plug to begin with. It may be moist or corroded. Once cleaned up the old throttle body should work ok. the old throttle body should always work with the car. if is stoped working it was not the trottle body itself. it was wires, moisture or corrosion, in the plus or the sensors. Clean and dry old throttle body since you have it off the car. Pop the end off where the plug is to be sure its all ok inside. then reinstall it to the car. It should work fine.
    I had to cut the pigtail off the car that goes to the throttle body and splice in a new used one. then installed a newer throttle body and reprogramed it.
    Feb 2011
    40
    23
    thanks. The wires look good. I tryed to clean the old throttle body before I found the last new one in the country. I think I will go ahead and try and find a new wire harness and splice it as well. I mean it looks good, but your right and thats what I was thinking to thought it was just a bad conection. I have an appointment to drop it off Friday at the dealer for updates and programming. Hopefully I can find a new/used conector to splice before hand. Thanx again
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    If I remember correctly, you can program the throttle body by yourself. I had to replace my in laws 2001 catera throttle body last year and programmed it by following some steps. I cannot remember exactly how it was done...may be I have to search in my old subscribed posts in here.
    Sep 2007
    1,024
    Also , is the car turning on or the engine idling strange........could it be the MAF?
    Feb 2011
    40
    23
    yeah it starts everytime and idles pulsing between 900 and 350 I unplugged the MAF and no change in idle when I press the gas the idle pulses a little higher maybe 1200 rpm but continues pulsing and doesnt open up.
  16. #14
    TitanCTS's Avatar
    Aug 2003
    Watertown, MA
    32
    199
    Unplug one of your O2 sensors and start it and see if it changes idle, Do this one at a time for all 4 O2 sensors to eliminate them.
  17. #15
    Feb 2011
    40
    23
    Thanks I will try that today just unpluged each coil pack one at a time and tryed each one yesterday.
  18. Remove Advertisements
