Quick Questions/Help Needed for New Owner
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Quick Questions/Help Needed for New Owner in Past Cadillac Vehicle Discussion; Fella's, I just bought an '01 Catera, 1 Owner with only 69,000 miles. I'm pretty mechanically inclined but on any ...
    Lil_Black_Cadi is offline Cadillac Owners Member
    Automobile(s): 2001 Cadilac Catera
    Jan 2011
    33
    PostQuick Questions/Help Needed for New Owner
    Fella's,
    I just bought an '01 Catera, 1 Owner with only 69,000 miles. I'm pretty mechanically inclined but on any new task/project I like to consult other sources of knowledge. There are a couple minor (I hope) issues that I want some thoughts on (they may or may not be related/connected).
    1. The low coolant light is always on, but the resevior is full. - This leades me to believe just a dirty/bad sensor (the car still has Dexcool in it which will be flushed ASAP)
    2. The temperature gauge basically doesn't work. It either is pegged 0 or will randomly jump up to a random temperature and hang out there before going back to 0. - Again, another sensor issue?
    3. The overheat light randomly comes on but not never in direct correlation to the temp gauge's location. - Doubtful it is overheating at 70mph in 5 degree weather but I want to be sure.
    Can anyone help direct me to the root cause of these and let me know what is needed as far as 1 sensor, multiple sensors or what other parts would be needed and what is cross compatible with a Saturn part.
    THANKS IN ADVANCE!!!
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Quick Questions/Help Needed for New Owner
    Sensor shot. Don't think it's available without tank.
    Pull instrument panel (search: dashboard, instruments). Check/clean connectors.
    Check for oil in coolant. Look for "mayo" under oil cap. It can plug the radiator. Cause: leaky oil cooler.
    Jan 2011
    33
    Quote Originally Posted by elvin315 View Post
    Thanks for the input. What would be the next area to check (for #2 & #3) if those aren't correct? It being my daily driver and 5* outside; I don't want to dive into the car on my off day to come up empty handed in this weather and not have it fixed come time to go to work again.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    It sounds like an engine temp sensor?? maybe?? also knwo that the cateras are know to blow head gaskets.. how about an engine block smoke test??
    The car is very old.. so the sensors would be my first plan of attack.. if no oil and coolant mixing.
    Good luck! mine has 130K on it.
  7. Remove Advertisements
