water soaking up through passenger side carpets front&back
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, water soaking up through passenger side carpets front&back in Past Cadillac Vehicle Discussion; recently there has been water soaking up through the bottom of my passenger side front and back carpets. iv heard ...
    wyse18 is offline Cadillac Owners Member
    Automobile(s): 2000 catera base model
    Jun 2010
    27
    97
    recently there has been water soaking up through the bottom of my passenger side front and back carpets. iv heard that it is probably a drainage issue seeing as it only started to happen about 3 weeks ago and all the leaves and debris from fall in atlantic canada brings about a lot of crud that could be my the root of my problem. iv heard that clearing the drain from the cabin filter is the solution but im not sure where to find the cabin filter. this might also be the reason why some of my electronic systems may be malfunctioning including the check engine light which has turned on and then off again a few times, turning on after a wet one and then turning off after a few days of dry weather. if anyone could aid me in my struggle that would be much appreciated from a fellow catera owner. thanks
    AL Cool Dates is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Catera Sport
    Aug 2010
    Bronx, New York, United States
    91
    Re: water soaking up through passenger side carpets front&back
    Its your cabin filter drain, its clogged and once the cabin filter fills with water the rest drains into the cabin passenger side. Open your hood and on the passenger side near the windshield right there under the passenger wiper blade is the cabin filter. You are going to see what looks like a vent, thats the compartment, take the vent off and you have access to it. The drain is at the bottom of the compartment, I'm not sure how to unclog it though, my mechanic did it for me.
    Here is a pic, top left above the strut, that leaf is right on top of it.
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    that look like a 97-98 engine
    Aug 2010
    91
    Quote Originally Posted by waco-brian View Post
    Got the pic from car domain, I didn't really look at the year but you may be right. The cabin filter should be located in the same area as all models right?
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Quote Originally Posted by AL Cool Dates View Post
    It is a 97-98. The cabin filter is the same on all years. There are drains on each side, the driver's is clearly visible when you pop the hood. The passengers side causes the most problems, but both should be cleaned.
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    If you can't completely clear the drain hole at the bottom of the filter compartment working from the top, here is the best tip I ever got on this forum:
    Turn your front wheels to the left and look into the right wheel well. There will be a plug at the top of the wheel well. Open this plug and you will see water and crud gush out.
    Barry.
  9. Remove Advertisements
