2000 heat problems
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, 2000 heat problems in Past Cadillac Vehicle Discussion; i was wanting to know if anyone has had this problem i have heat coming out of the passenger side ...
    joshp is offline Cadillac Owners Member
    Dec 2010
    34
    1
    2000 heat problems
    i was wanting to know if anyone has had this problem i have heat coming out of the passenger side vents and cold coming out the driver side
    rteal8150 is offline Cadillac Owners Member
    Automobile(s): catera
    Dec 2010
    60
    1
    Re: 2000 heat problems
    i would like to know if you know anybody out there that might know what causes the heater to blow heat then go to regular air and the a/c does the same thing blows cold air then goes to regular air, i dont hear any doors closing or opening but totally lost why itwould do this if you could be of help let me know
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Bad control panel, from my experience
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Nov 2009
    Rochester NY
    37
    449
    controll panel.. do yu mean the part in the dash witt he buttons yo push?
    If so... I have one. the face will need to be swaped with your face cause the display has a crack and I swiped the lights behind the buttons for mine. but the actual part itsel I did use. I got it used from a 97 cat I think.
    R-Caddy's Avatar
    Jul 2005
    Savannah, GA
    32
    698
    Yup. That panel fixed a lot of my problems
    mdksupra is offline Cadillac Owners Member
    Automobile(s): 2001 Catera, Platinum
    Jan 2011
    32
    45
    do you believe it to be that panel instead of the blend door? i have the same issue and was about to check out the blend door in the passenger side
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    The temp sensor is located in the ac control panel, it's possible it goes out. Have you tried turning the temp to 90 or 60 and then manually control the fan to keep temp moderate?
    Jan 2011
    32
    45
    what do you mean by manually control the fan? try to move the actuator open/shut?
  11. Remove Advertisements
