Catera crankshaft position sensor Oil Leak
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Catera crankshaft position sensor Oil Leak in Past Cadillac Vehicle Discussion; Recently got this 1998 Catera, Just had to have the cps replaced, now I see puddle of oil under car ...
    pulnchevy is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Nov 2010
    70
    4
    Recently got this 1998 Catera, Just had to have the cps replaced, now I see puddle of oil under car after driving 250 miles. Saw the old sensor has an o-ring. Does it enter an oiled area? Is this likely the cause of the leak? Was totally dry shortly before this repair.
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    Re: Catera crankshaft position sensor Oil Leak
    ther are a few things to check in that area, the filter, the oil cooler lines and the sensor, most likely the filter
    Nov 2010
    70
    4
    Got it on the lift and found the oil running down both sides of the block, from somewhere at the upper rear of the engine by the area the mechanic was in to plug in the new CPS. Is there something in that area he could of knocked loose or left disconnected to explain this oil leak ?
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Quote Originally Posted by pulnchevy View Post
    I believe the main oil pipes from the oil cooler from the engine block come around from that area.
    May be worth checking everything is good. It should be dry like before other than minor staining from oil changes near the oil filter assembly.
    Good luck.
  7. Remove Advertisements
