Steering Shake
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Steering Shake in Past Cadillac Vehicle Discussion; Hey guys, my 2000 catera sport's steering wheel seems to shake a bit starting around 40 mph and gets worse ...
    AL Cool Dates is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Catera Sport
    Aug 2010
    Bronx, New York, United States
    91
    Steering Shake
    Hey guys, my 2000 catera sport's steering wheel seems to shake a bit starting around 40 mph and gets worse as you speed up. You also can feel it when you rest your left foot on the raised portion on the left side of the brake also. I just had the front struts and sway links replaced so I can rule those out. Any ideas?
    Cadi Cat is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera
    May 2005
    Michigan
    32
    314
    Re: Steering Shake
    could be anything. Bent wheels, tires need balancing, worn balljoints, control arm bushings, tie rods ends, alignment. One thing you could do to rule out the mechanical issues is to put the front tires on the back and see if that helps any.
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    Re: Steering Shake
    bent wheel, bad tire, junk in the tire, control arm bushings, wheel balence.
    Aug 2010
    91
    Re: Steering Shake
    Alright, I will try switching the tires. I had an alignment done when the struts were replaced a month ago and I can't see that as bad but this car has surprised me a few times. I will have my mechainc look at the other stuff but it makes me wonder why didn't they spot that stuff when the struts were replaced unless there was nothing of real concern.
  7. Remove Advertisements
