brake light harness question
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, brake light harness question in Past Cadillac Vehicle Discussion; Hi, I had an accident and my driver side brake light doesn't work most of the time..reason being the metal ...
    wassupman is offline Cadillac Owners Member
    Automobile(s): catera
    May 2010
    Hi, I had an accident and my driver side brake light doesn't work most of the time..reason being the metal harness that holds the bulb in place was damaged. I tried using electrical tape to hold the bulb in place but it just won't work. My questions are:
    1) What is the piece of equipment that holds the bulb called? It is black metal/plastic and has some wires coming out the back. I tried searching for "brake light wiring harness" but didn't see much so I'm guessing that isn't it.
    2) Where can I get one? Is salvage yard my only option?
    Thanks.
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    65
    343
    Re: brake light harness question
    Quote Originally Posted by wassupman View Post
    Thanks.
    Try the following site as I put in Catera 2000 as a selection (an example) and it lists the parts and assemblies and cost,
    http://www.compnine.com/index.php?u=...02&grouptype=B
    eBay is a good source and specially the eBay UK site and look for Vauxhall Omega parts.
    Good luck.
    May 2010
    Thank you so much! That is very helpful!
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Funny, I had the same problem with my driver's side brake light and I was never in an accident. The problem is that when you insert the bulb and twist to lock, the two halves of the metal socket separate so they don't hold the bulb properly. Rather than try to hold the bulb in with electrical tape, I used the tape to reinforce the two halves of the socket so they stay together rather than separate due to the force of the bulb. So far, so good.
  7. Remove Advertisements
