2001 Catera, slow to accelerate - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Cadillac Catera and Cimarron Forum Discussion, 2001 Catera, slow to accelerate in Past Cadillac Vehicle Discussion; The car has new tires and everything is balanced. I think there is seal that secures the shift which may ...
  1. #16
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,025
    Re: 2001 Catera, slow to accelerate
    The car has new tires and everything is balanced. I think there is seal that secures the shift which may have gone bad. The gear lever does not vibrate during driving or braking, but when you hold the shift it rocks back and forth. In regards to the acceleration issue, the car is running fine and I think the roughness or slow accelerate they might be feeling could be from the new issue I found. There is a good leak in the back by the differential area, so I think the gear oil is low and the seal may need replacement. I'm not sure whar parts are needed for that and how hard it may be to replace it.
    Thanks.
  2. #17
    WGoins88's Avatar
    WGoins88 is offline Cadillac Owners Member
    Automobile(s): '97 Catera
    Aug 2009
    Amherst, OH
    28
    80
    One of the biggest problems with the 4L30-E is the range sensor on the side of the transmission (Where the gear selector is) gets all goobered up. It's a VERY common thing on the Isuzus and BMWs with the 4L60-E. Best thing to do is to take the sensor off and clean it... as seen here
    http://isuzufaq.ibctech.ca/range.pdf
    The range sensor being dirty causes all kinds of things, INCLUDING transmission failure.
  3. Remove Advertisements
