Trunk lock
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, Trunk lock in Past Cadillac Vehicle Discussion; Hi all, Hope someone can give me some help on a small problem. When I open the trunk on my ...
    mrkap is offline Cadillac Owners Member
    Automobile(s): Catera
    Oct 2010
    52
    7
    Trunk lock
    Hi all, Hope someone can give me some help on a small problem. When I open the trunk on my 1999 catera it will not lock again unless i press the lock button on the romote. I then can close it.
    Any Ideas?
    Thanks
    Peter
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: Trunk lock
    Quote Originally Posted by mrkap View Post
    Any Ideas?
    Thanks
    Peter
    Probably just some stickiness or like in the lock mechanism and latch. Clean and perhaps a bit of WD-40. Worth the try if I were to do it.
    Cheers.
    PS: For your other post, there are 4 ABS sensors. There are two in the front one on each wheel. There are two located behind on the differential housing at the rear of the car. If you clean and use some electronic contact spray and then reseat it perhaps will help correct the issues.
