1999 Catera TC ABS and speedo not working
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, 1999 Catera TC ABS and speedo not working in Past Cadillac Vehicle Discussion; Hi, I have a 1999 Catera. The speedometer has stopped working, and also the ABS light, and TC light are ...
    mrkap is offline Cadillac Owners Member
    Automobile(s): Catera
    Oct 2010
    52
    7
    Hi, I have a 1999 Catera. The speedometer has stopped working, and also the ABS light, and TC light are on. On occasion everything works but most of the time I am having this problem. Any ideas of what I can do?
    Thanks
    Peter
    Kodan is online now Cadillac Owners Member
    Automobile(s): Opel Omega Limousine 3.2 Executive | 2003 | Automatic.
    Oct 2008
    The Netherlands
    99
    Re: 1999 Catera TC ABS and speedo not working
    The problem is the ABS/TC ecu or one of the abs sensors that are located near the differential.
    There could be a problem with the plug that is connected to the abs ecu or the connectors of the rear abs sensors.
    The best thing is go to your dealer and check with the Tech2 if there is a DTC from the ABS/TC ecu.
    Peter
    Oct 2010
    52
    7
    thanks, Now is the TC, ABS ecu also called the BCM. I also read about the K134 relay, any merit to that?
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Quote Originally Posted by mrkap View Post
    thanks, Now is the TC, ABS ecu also called the BCU. I also read about the K134 relay, any merit to that?
    I don't know about a BCU model but there is a BCM module. The BCM module or relay K134 is a multifunction electronic assembly which controls functions like radio, auxilliary water pump, trunk and gas lids remote opening, etc. It does not have anything to do with brakes from what I know unless its inputs are used for some interlock functions like you cannot open doors electronically in a moving car, etc.
    Cheers.
    Oct 2010
    52
    7
    Thanks all for the input. I will check my ABS sensors. I got the car washed and everything started working. but after driving for a bit its acting up again Intermitently.
    Thanks
    Peter
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    45
    601
    More than likely,the EBCM is at fault.It is mounted to the BPMV on the L/F behind the battery. It's pretty pricey too.
    dadenkern is offline Cadillac Owners Member
    Automobile(s): 2001 Catera
    Oct 2005
    Minnesota
    35
    49
    The failed component is likely the EBTCM. I just recently pulled it from my 2001, sent it to ModuleMaster.com, they repaired the unit and after installing the speedometer and ABS work great.
    $160 +shipping
    http://www.modulemaster.com/en/Cadillac/Catera_info.php
    Oct 2010
    52
    7
    Thanks everyone for the help. It did end up being the ABS module. Got a used one online at a for 100 plus shipping. fixed up all the problems.
    Thanks again,
    Peter out
  11. Remove Advertisements
