what does the cd changer harness look like?
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, what does the cd changer harness look like? in Past Cadillac Vehicle Discussion; Hi all! I have a 1997 Catera without the cd changer. I am looking at the ipod units that connect ...
    drakenhol is offline Cadillac Owners Member
    Automobile(s): 1997 Catera
    Aug 2010
    Manitoba, Canada
    50
    8
    Hi all! I have a 1997 Catera without the cd changer. I am looking at the ipod units that connect to the cd changer wiring harness. However, I have looked in the trunk and all i see is a 6 / 4 split female connector with double row of 10 pin each. is this the prewired connector?
    does anyone have pictures of the harness or what it connects too? The stereo I have is a bose am/fm/cassette.
    Your help is greatly appreciated.
    should say too that I am looking at this because I would like to hook up my iPod. Some of the auxillary boxes out there say that you have to have the wiring for the cd changer in order to hook the unit up. Also read that Cat's were prewired if you had a bose... Not entirely sure if that is true or not! The replacement GM part for wiring is #12484910. Unable to see what that looks like either. Even the dealer does not have pictures.
    Hope someone can help!
    z28hellrazer is offline Cadillac Owners Member
    Automobile(s): Catera
    Sep 2010
    21
    Re: what does the cd changer harness look like?
    i have a 98 catera and for s's and giggles I looked into this aswell. I also have bose and my research shows that the bose cd changer was mounted in the right hand side of the trunk as soon as you open the trunk lid. The connector you have seen is in fact the prewired amp hook up I cannot tell you much more than that. I only recently purchased my catera and although im an audio man, the replacement motor is more important at this time.
    Aug 2010
    Manitoba, Canada
    50
    8
    Thanks Hellrazer! Much appreciated. Now I can at least look at those auxillary boxes so I can add the iPod. Btw, good luck with the replacement motor. I have seen some new and used ones on the net, plus somebody posted here the possibility of using one of the 3.2l cts engines.
    Best of luck!
    Aug 2010
    Manitoba, Canada
    50
    8
    Sorry, had to repost, pre-wired amp hook up? Not the optional CD hookup? Wonder if I am prewired for the cd hookup at all...
    Sep 2010
    21
    a good way to tell would be to check the owners manual for how to use the cd changer via the factory bose headunit and see if your bose head unit has the buttons for the funtion.
    Sep 2010
    21
    and thanks im hoping it goes smoothly like everyone else has said theirs was only im going to post pictures for the proof.
    Aug 2010
    Manitoba, Canada
    50
    8
    I checked the manual and it shows the exact same thing i have. Bose with cassette, a source button that changes from cassette to cd changer. apparently there are no auxiallry connections on the back of these bose head units. I think the CD changer is wired in through the harness to the back of the head unit.
    so the info I had found said if the vehicle has been pre-wired it woudl be located in the compartment at the right rear of the vehicle behind the section with the 2 clips. That is where I found the female end of a connector with a 6 / 4 split total is 2 rows with 10 pin ports. Was curious if this was the connection for the CD changer or if the cable gm part no#12484910 connects into that. If not does it connect directly to the head unit?
    So far I am batting a poor average. Tried GM and several parts places and they either don't have a cable or a picture of one so I know. Can't even find pictures on the internet for it. I will post what connection I do have so you can see it.
    Aug 2010
    Manitoba, Canada
    50
    8
    Here is a picture of the connector that is in the rear of my catera. It is located behind the panel with the two clips just forward of the tail lights.
    Hopefully this is the actual pre-wired connection to attach the optional cd changer. I have my doubts though.
  11. Remove Advertisements
