1998 catera: Engine temperature needle is stuck on nil/zero temperature
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, 1998 catera: Engine temperature needle is stuck on nil/zero temperature in Past Cadillac Vehicle Discussion; Ok. 1998 catera- this car now runs fine and the Engine check light is NOT ON; but the temperature needle ...
    1sontov is offline Cadillac Owners Member
    Automobile(s): 1998 catera
    Aug 2010
    14
    Ok. 1998 catera- this car now runs fine and the Engine check light is NOT ON; but the temperature needle (far leftside) of the dashboard is stunk on Zero. No matter the driving conditions-- the needle doesnt not register tempature when the car is running.
    Is there a sensor for this? Could it be the thermostat has failed,... something not hooked-up properly...and if so, any suggestions as to basic trouble shooting techniques.
    Please advise - many thanks to all of you.
    Sontov
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: 1998 catera: Engine temperature needle is stuck on nil/zero temperature
    Quote Originally Posted by 1sontov View Post
    Sontov
    1sontov are the radiator and auxiliary fans working good? Hopefully something loose electrically if the fans are working.
    It is quite an important sensor on these cars and I believe extremely awkwardly located.
    Cheers.
