brake light switch too short when installed in 1999 catera
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, brake light switch too short when installed in 1999 catera in Past Cadillac Vehicle Discussion; anyone else have this problem? i replaced the brake light switch with a new one from napa and the switch ...
    andyr0cks01 is offline Cadillac Owners Member
    Automobile(s): Catera
    Sep 2010
    1
    anyone else have this problem? i replaced the brake light switch with a new one from napa and the switch is not being pressed on by the brake pad bar. it cannot be pushed into the bracket that holds it anymore then it is...
    eastsidercaddy's Avatar
    eastsidercaddy is offline Cadillac Owners Fanatic
    Automobile(s): '97 Black Catera
    Jan 2008
    Jacksonville NC
    27
    210
    Re: brake light switch too short when installed in 1999 catera
    get a flashlight and look all the way up on the brake pedal bracket. You'll see the yellowish plastic rod coming out of the switch. It automatically adjusts to the brake pedal when it hits the rod. Depress your brake pedal, take a flathead screwdriver and easily pry on the rounded part of the rod. This will extend the rod out so when the brake is released it will hit the brake pedal.
    I recently had to do the same thing because my brake lights were not working. Pretty easy to do and understand. If you have any questions reply back on this thread and i'll post pics. Hope that helps.
