Oil in my coolant
Results 1 to 14 of 14
Cadillac Catera and Cimarron Forum Discussion, Oil in my coolant in Past Cadillac Vehicle Discussion; I own a 98 Catera, I recently noticed my engine oil has mixed my coolant. My mechanic said I have ...
    Elliot Roby is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Catera
    Sep 2010
    42
    3
    Oil in my coolant
    I own a 98 Catera, I recently noticed my engine oil has mixed my coolant. My mechanic said I have a bad oil cooler. My question is will replacing the radiator fix this problem? Or is there another solution?
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Re: Oil in my coolant
    It's got nothing to do with the radiator other than it getting clogged. The culprit is the oil cooler like the mechanic said. Replacing it is the only answer. Search here for more info.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    sometimes the cooler itself is not leaking but all the seals involved in that area down in the V between the two heads, as well as the coolant crossover seals (where the coolant temp sensor plugs in)
    we only replace the cooler if it is actually leaking since it is pretty expensive
    the same problem happens to all OPEL 3.0L v6 engines -- we've done a lot of these repairs to saturn l-series cars (more than on cateras actually)
    the parts kit for the catera includes a new crossover with all the seals (only way from a gm dealer to get the seals for the crossover) but if you go to a saturn dealer they will have the seals as individual numbers
    if you'd like i can pull up the parts list that we use on this job (for saturns) for you on monday - it should be exactly the same for a catera
    Sep 2007
    Wilmington, NC
    13,986
    i may have jumped the gun
    if you have oil in the coolant then maybe the cooler is the culprit
    either way email or PM me for price quotes if you'd like a deal on OEM parts
    Sep 2010
    42
    3
    Thanks guys.
    Sep 2010
    42
    3
    Quote Originally Posted by rippypartsmaster View Post
    I'd like that very much if you can.
    Sep 2007
    Wilmington, NC
    13,986
    hittin' the hay for now, i'll get back to you in the AM
    Sep 2007
    Wilmington, NC
    13,986
    Haven't forgot about you, just a bit busy this morning... i'll get back soon
    Sep 2007
    Wilmington, NC
    13,986
    sorry this has taken so long - very busy day at work, the afternoon was just worse than the morning
    ... Mondays ...
    but anyway here's what we do for parts on a 3.0L saturn (and catera) oil cooler area coolant leak
    [FYI: all prices are list]
    #11076852 $1.86 x4 (metal oil cooler banjo bolt seals) #55 in the 1st illustration
    #90409175 $1.83 x2 (rubber oil cooler seals) #51 in the 1st illustration
    #24455322 $4.04 x2 (new design t/stat housing bolts) #46 in the 2nd illustration
    #55353492 $64.92 (new design t/stat and housing w/ seal) #45 in the 2nd illustration
    #09129999 $6.68 x2 (t/stat to pipe seals - there's two right next to each other on that pipe - be careful removing it the bolt ear will sometimes break) #47 in the 2nd illustration
    #12992647 $9.50 x4 (coolant cross-over seals - these are the ones that are only for 00-05 L-series and 03-04 vues and 03-04 cts -- on the catera they want you to buy a new cross-over design that comes with the seals but you can just get these seals) #40 in the 2nd illustration
    plus dexcool and an oil change and black RTV sealant around the cooler seal
    and on the newer vehicles that have the newer 'paper style' oil filter we do the filter housing-to-block seal/gasket
    (but your filter has a gasket that performs that function)
    if you need a cooler (i'm not sure how to tell if it's leaking, but usually it's not)
    the list price is $397.62 (forum discount is $265 plus tax and half shipping)
    so making sure that the cooler is not leaking and only leaking at the seals is going to be pretty important
    edit: also an afterthought - sometimes we replace the banjo bolts but that's usually not needed
    and here's the pictures
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    You could also look into aftermarket, there is a recent thread I just replied to asking about it.
    Pamela Delgado-Burt is offline Cadillac Owners Member
    Automobile(s): 99 Catera
    Sep 2010
    I need help. I have a 99 Catera w/72,000 original miles.There is oil in the coolant. I am told I have blown gasket. One mechanic say replace the engineer. Another say $2500 to replace the gasket. What do I do?
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    65
    343
    Quote Originally Posted by Pamela Delgado-Burt View Post
    I believe the initial indication should be "Oil Cooler" and it is not $2500 job. See also as per rippypartsmaster in the following,
    http://www.cadillacforums.com/forums...ml#post2360399
    If you have and continue to drive expect continuous and more major damage very quickly repair expenses will mount.
    Take care.
    Sep 2010
    Thank you USEDCAT
  16. #14
    sassanach is offline Cadillac Owners Fanatic
    Automobile(s): 59,60,73,2000sts,2001sts,1999omega/catera
    Feb 2008
    melksham,england
    135
    kin ell $400 or $265 is a lot off dosh, the kit is approx £120 in blighty ($1.5 to a £1
  17. Remove Advertisements
