tire spec question
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, tire spec question in Past Cadillac Vehicle Discussion; can 17inch tires fit on my catera that has 16inch tires on it now?...
    wyse18 is offline Cadillac Owners Member
    Automobile(s): 2000 catera base model
    Jun 2010
    27
    97
    tire spec question
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: tire spec question
    Quote Originally Posted by wyse18 View Post
    The following from the Catera 2000 User Guide
    The Tire-Loading Information label, which is located
    on the rear edge of the driver’s door, shows the correct
    inflation pressures for your tires when they’re cold.
    “Cold” means your vehicle has been sitting for at least
    three hours or driven no more than 1 mile (1.6 km).
    If you’ll be driving at speeds higher than 100 mph
    (160 km/h) where it is legal, raise the cold inflation
    pressure of each tire to,
    - 38 psi (260 kPa) for tire size P225/55R16
    - 39 psi (270 kPa) for tire size 235/45R17
    When you end this very high-speed driving, reduce the
    cold inflation pressures to those listed on the
    Tire-Loading Information label.
    So from this I have to assume that 17" rims with 235/45R17 size tires should be good.
    Better check with Tire manufacturers allowed tires guides when you search for your car to be double sure.
