stainless steel brake lines for rears - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac Catera and Cimarron Forum Discussion, stainless steel brake lines for rears in Past Cadillac Vehicle Discussion; Originally Posted by wyse18 how do i know what caliper will fit if i get the slotted rears Calipers only ...
  1. #16
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    65
    343
    Re: stainless steel brake lines for rears
    Quote Originally Posted by wyse18 View Post
    Calipers only one design that will fit the rear. You should match pads and rotors for slotted versus non-slotted.
    For the calipers,
    http://www.autozone.com/autozone/par.../N-jegtxZ8knrp
    Pretty compelling.
    Original Part Numbers:
    90543586 CALIPER,RR BRK(LESS PADS)(ACDelco #172-2360) L
    90543587 CALIPER,RR BRK(LESS PADS)(ACDelco #172-2361) R
    Cheers.
  2. #17
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    if those autozone calipers are available they are a great deal
  3. #18
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    i was going to order the slottled and dimpled for the front and slotted for the rear from brake performance. do i need a wider caliper? im not really sure iv just been trying to gather parts so i can get this done. my brakes are so vibey that it dosnt feel safe anymore lol
    When we say vented it means the disc has hollow channels between its outer surfaces. Solid means solid. Drilled, dimpled, or slotted has no bearing on the discs thickness. All Catera front discs are vented. '97 - early'01 rear discs are solid. Late '01 rear discs are vented. Remove the rear wheel and look at the circumference edge of your rear disc. If it has holes it's vented. If not, it's solid.
    Like I said above, slots make no difference. If your disc is solid you need the narrow caliper. If it's vented you need the wide caliper. I don't know the Part numbers. Maybe RippyPartsMaster can provide them for us.
  5. #19
    wyse18 is offline Cadillac Owners Member
    Automobile(s): 2000 catera base model
    Jun 2010
    27
    97
    i went out and checked and the front are vented but like stated, the rears are solid. if i was to get a vented rear discs, what calipers would i need to fit it? i would like make her vented in the back too
  6. #20
    Jun 2010
    27
    97
    i was checking online and i found a caliper that would fit with vented rear discs. it has a bore of 42mm. its called Posi-Quiet Loaded Caliper by centric parts. is says on the website that these are for vented rear discs and that it is for the catera.
  7. #21
    Sep 2007
    Wilmington, NC
    13,986
    yeah, my parts catalog doesn't really have good info on these types of 'swaps' - it just tells me what goes on that vehicle
    that said...
    i do see in the 2001 catera catalog that there are 1st and 2nd design calipers (and that they say for slotted or solid rotors)
    but the second design calipers (oem) are discontinued - the catalog doesn't even list the RH side 2nd design
    there are durastops available for the 2001 but there's no mention of which style they're for
    if i was you i would stick with the 1st design since there's way more cars out there with that (1997-2001) instead of the 2001 2nd design
  8. #22
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Would you please supply a link to that site?
  9. #23
    May 2005
    65
    343
    Quote Originally Posted by elvin315 View Post
    Elvin it is probably this site,
    http://www.autopartswarehouse.com/sk...n+%26+Steering
    or this
    http://www.rockauto.com/catalog/x,ca...,parttype,1704
    Cheers
    PS: In hindsight perhaps best left for Wyse to reply.
  10. #24
    Jun 2010
    27
    97
  11. Remove Advertisements
