2001 Catera ac fan not staying on
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, 2001 Catera ac fan not staying on in Past Cadillac Vehicle Discussion; Hi, It's been a while since I have been here. Anyways my catera has a new issue, maybe it is ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Hi,
    It's been a while since I have been here. Anyways my catera has a new issue, maybe it is normal but want to know if anybody had this problem before. Turned on the car today with the AC running and I could hear the AC fan kicking in then turns off. The fan runs for about 2 seconds and shuts down and happened several times. What could be the problem? Also, the temp gauge goes all the way to red once in a while. Could this be related to the AC fan issue?
    Thanks.
    Sep 2007
    1,024
    Re: 2001 Catera ac fan not staying on
    Anybody?
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    65
    343
    Quote Originally Posted by retho78 View Post
    Anybody?
    Retho78, do you have information to test the various fan conditions?
    The following should allow you to simulate various activations for fans,
    __________________________________________________ ________
    Fan test connector info: Open the engine bay fuse and relay box, and you'll see a 6 pin test connector attached to relay K87 ( count 6 back from front of car ). Pins are numbered 123 left to right, 456 right to left. With pin1 top row left if you look at the connector with the two keys on your left hand side. ( I'll try and post a picture as soon as I've worked out how.. Can't find an upload option ).
    My car has 3 fans, two ostensibly for the air conditioning, in front of the air con radiator right at the front, and one behind the engine's radiator.
    Pin 1 = coolant temp switch output stage 1 ( quite hot )
    Pin 2 = pressure switch output
    Pin 3 = +12 ignition on - via fuse 29 on my 3.2 Elite - NOT fuse 15
    Pin 4 = coolant temp switch output stage 2 ( very hot )
    Pin 5 = coolant temp switch output linked to air con
    Pin 6 = earth
    So, if you earth the following pins, the folowing happens ( or should )
    Pin 1 when earthed, runs both air con fans slowly.
    Pin 2 when earthed, runs NS air con fan fast.
    Pin 3 +12 V ( Don't earth this !, unless you want to blow a fuse ! )
    Pin 4 when earthed, runs radiator fan ( big one behind radiator )
    Pin 5 when earthed, runs NS air con fan fast. ( Same as 2, but via a different relay ).
    I forgotten where I got this info from but it is not my original and I have not verified it either.
    Good luck.
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    I believe mine only come on when needed, even if the AC is on.
    May 2005
    65
    343
    Anybody?
    Little more technical info if it helps,
    Engine Cooling Fans (A/C Operation): When A/C compressor is turned on, fan control relay K87 is energized and auxiliary engine coolant fans 1 and 2 will operate in low speed. In order to prevent inadmissible high refrigerant pressure in refrigerant circuit, auxiliary engine coolant fans 1 and 2 are switched from low speed to high speed at refrigerant pressures above approximately 275 psi. When pressure drops less than about 217 psi, auxiliary engine coolant fans 1 and 2 are switched back to low speed.
    Good luck.
    Sep 2007
    1,024
    thanks will give a try and see what happens.
    Sep 2007
    1,024
    so, could it be that relay K87 is faulty?
    Jun 2007
    Mooresville, IN
    26
    677
    Try swapping it with another of your relays. (do low or high headlights use the same relay?) I think like 4 of the relays are the same, maybe a/c fans is one of them.
    Sep 2007
    1,024
    okay, will swap it out and see if the fan will stay on.
  12. Remove Advertisements
