I have a 97 catera and i'm having a weird problem with my air suspension. When i'm alone in the car the leveling light does not come on whatsoever, but when i have passengers it starts blinking and never stops until i turn off the car. What could be the problem? I don't have any leaks or anything.
I've had this same issue, but for other reasons- fixed the front suspension on my 1998 catera: start with the basic, least expensive fixes first-- check tire pressure and break fluid level. how does the car handle-- is the front suspension solid or does it knock a little-- be honest with youself... does it pull to one side? how old are the front suspension parts on your car? My front suspension was getting sloppy/loose (parts wear out)... I know that once I had new inside/outside L & R tie-rods installed + new idler arm (passager side) + center link installed (by the shop)... then I installed the link pins myself (cause the shop wanted too much $ for something sooo basic)...Once all this was done - especially the link pins installed, I honestly felt the car sit higher up and it felt more stable. Amazing when parts wear it can cause this 'leveling' light to flash. <Thats my opinion> No matter if you 'think' its NOT an air leak issue-- I strongly believe these same parts (tire rods, idler arm-to-center link + link pins) on your car are wearing out and getting sloppy-- thats why the ELE system is recognizing the suspension is 'no-longer level' [stable], and the light comes on- flashes.
I'm assuming you're talking about the rear bushings. If so, yes I would think so. Check the front bushings. You'll probably find them shot too. Read my write up regarding Catera suspension upgrades.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
