coolant leaking from corroded washer?
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, coolant leaking from corroded washer? in Past Cadillac Vehicle Discussion; I have a 97 Cat. Of course i have a coolant leak. After thinking its the oil cooler a friend ...
    Marcusmak is offline Cadillac Owners Member
    Automobile(s): 1997 Catera
    Aug 2010
    4
    I have a 97 Cat. Of course i have a coolant leak. After thinking its the oil cooler a friend and i took apart the intake and spacer. We inspected every area know to leak top and bottom and could not diagnose it to any of the main areas i.e. cooler, hoses, radiator, thermostat. What we did find is a corroded stat o seal washer that is on the part where the coolant sensor is. It seemed like it was leaking from that area. We found residual coolant around the drivers side of the spacer and when inspected from underneath it seems likes it coming from above the cooler lines. The only time it would leak would be when i shut it off. I also had a mechanic read the engine codes and he told me it was the coolant sensor. So it seems like that is where the leak is. Please give me your thoughts.
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: coolant leaking from corroded washer?
    Quote Originally Posted by Marcusmak View Post
    There is an Auxiliary water pump which comes on when you turn the car off. It circulates the coolant to cool the engine off when you shut the car and engine is still hot.
    It is located near the battery on the driver side and is electrically driven.
    Cheers.
    Aug 2010
    4
    Thanks I will check that out tomorrow. I'm going to pull the battery and try to see if i find any residual coolant. I'm going to post what i find but i did see a few other people with the same leak. Heres hoping that its only the washer.
