Changed the Multifuntion Relay on My Catera and still no radio!!!!!! What should I do
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, Changed the Multifuntion Relay on My Catera and still no radio!!!!!! What should I do in Past Cadillac Vehicle Discussion; After changing my multifunction module with a brand new one, hoping my radio would work it still does not, checked ...
    ExcursionBoy1984's Avatar
    ExcursionBoy1984 is offline Cadillac Owners Member
    Automobile(s): 2000 Black Catera Sport
    Jun 2010
    32
    57
    After changing my multifunction module with a brand new one, hoping my radio would work it still does not, checked all the fuses and still no luck, what should I do next guys, I really want my radio running once I start driving my catera.
    Thanks Guys
    Luke
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: Changed the Multifuntion Relay on My Catera and still no radio!!!!!! What should
    Quote Originally Posted by ExcursionBoy1984 View Post
    Thanks Guys
    Luke
    Did you by any chance replace the radio in the car from another car. These radios have anti-theft lock I believe.
    Jun 2010
    32
    57
    no this radio was in the car when i bought it, when i did touch and move around the original multifunction module the radio would come on and then it stopped coming on at all, resoldered the board had no luck, so then bought the new multi-function module and still no luck (what do u think it is)
    May 2005
    66
    343
    The way you have described it appears that there is a potential harness to module mating issue. You may want to go back to the old module but check the mating harness and perhaps spray some electrical contact cleaner before installing the module. Outside of that I can only think of fuses.
    May also want to re-check the following,
    - Fuse number 8 (Radio/Battery Guard), this is a control fuse which allows the BCM to protect the battery from excessive drainage when you turn the car off
    - Fuse number 10, BCM
    If something else comes to mind I will post.
    Good luck.
    Jun 2010
    32
    57
    I have also read up a little bit on the auxillary pump maybe the problem does anybody have more information on this issue maybe causing the problem.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    if by chance you need a radio let me know. I doubt that is your problem though. I thought mine was bad and bought a used one but it wasnt the radio. So I have a radio out of a 97 catera. I have vin # so it could be reprobgramed. like $20 for the radio plus shipping if you need it. and you need to email me directly. I have deceided to sell my catera once its fixed. I cant afford the repairs all the time!.
    HGQGUY@YAHOO.COM
    cadillac_tech is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX
    May 2007
    Parker , CO
    403
    Aux water pump shorts blows fuse, then radio works only in RAP mode (key off after on with doors closed). Not sure if this fits 2000 model, but was common in prior years.
    Lizzys Cat is offline Cadillac Owners Member
    Automobile(s): 2000 Catera!
    Aug 2013
    10
    If you are having the radio issue where it won't power on in position 2 and only key position 1 upon shutdown, check fuse #10 for the aux water pump. This was our issue and not the K134 MF relay.
    Torybutler123 is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac catera
    Jun 2016
    1
    I have the same issue my multifunction relay was ticking along with my roof lights when I turned the key to the first and second turn and the only way to stop the ticking is to turn the headlight switch from off to the second sign or I have to disconnect the relay please can someone help me with this... Much appreciate
  12. Remove Advertisements
