'98 Catera Evap Can Vent Valve Needed
Results 1 to 11 of 11
Cadillac Catera and Cimarron Forum Discussion, '98 Catera Evap Can Vent Valve Needed in Past Cadillac Vehicle Discussion; My 98 Catera needs a vent valve (part number 90541907) to pass the emissions test. I have called part stores, ...
    dchkunz is offline Cadillac Owners Member
    Automobile(s): '98 Catera
    Jul 2010
    4
    My 98 Catera needs a vent valve (part number 90541907) to pass the emissions test. I have called part stores, dealerships, official GM parts distributors and no one can find one. Is anyone parting out a Catera or know of a salvage yard that would likely have one? I'm open to just about any solution.
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Re: '98 Catera Evap Can Vent Valve Needed
    Try car-parts.com. Do a search for something generic like a hood, fender, etc, to find a local yard that at least has a catera, then call them and see if you can work something out.
    d_phekt is offline Cadillac Owners Member
    Automobile(s): Catera
    Jun 2010
    17
    There is a yard near me that just got a Catera in on Friday, so I am going to go check it out tomorrow. I'm not too sure what part you're talking about exactly, but if you could let me know I will grab it for you.
    Jul 2010
    4
    I can't post links or pm right now because I'm a new member but if you go to
    "gmpartsgiant[d]com[s]components[s]1998-cadillac-catera~fuel-supply-fuel-lines-ov030020103-l81ml46vr69[d]html"
    [d]= .
    [s]= /
    Stupid spam blocker.
    It's number 42 on the diagram. On the car, its located in the top left corner under the hood. It should be pretty easy to remove.
    Jun 2010
    17
    Alright. As long as it's still there I will grab it for you.
    Jun 2010
    17
    I was able to pick up that part for you. I can't send private messages yet, so shoot me an email with your info and I'll get it in the mail asap.
    d_phekt@msn.com
    Jul 2010
    4
    Mechanic just called. He said it might just be a sensor. He's going to check it out. I might not need the part after all! Thanks for grabbing it though. I'll let you know if I need it or not!
    Jul 2010
    4
    It's all fixed! Thanks for your help!
    locksmith Guest
    please let me know what sensor he replaced im having that evap problem as well thanks.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by locksmith View Post
    If u have evap small leak code. There is return pipe goes in to gas tank from electronic vavle in the front of gas tank. That pipe was cracked, I have to take tank down to replace it.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
  14. Remove Advertisements
