2000 Catera stuck in park
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, 2000 Catera stuck in park in Past Cadillac Vehicle Discussion; I have a 2000 Catera. It won't shift out of park. The shift to park light stays on. I've rocked ...
    sburke is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    I have a 2000 Catera. It won't shift out of park. The shift to park light stays on. I've rocked it & jacked up the rear end nothing seems to work. Any ideas?
    Thanks,
    Steve
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: 2000 Catera stuck in park
    Quote Originally Posted by sburke View Post
    Thanks,
    Steve
    There is an interlock between brake and shifting. As you know one can not shift without Braking from park you may want to look into the fuses or related areas if you have some documentation. Maybe the BCM/ECU is not seeing the brake signal or the key turned on signal.
    Cheers.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Lift the boot from around the bottom of the shifter. If I remember correctly, there's a yellow pawl the blocks the shifter from moving. If you push that you will be able to move it out of park. Of course now you have to figure out why that happened. Spray the shifter mechanism with WD40 to start with. If that doesn't help remove the cover off the steering column and inspect the ignition interlock. Something might be jammed up or broken there. Might as well lube it too. Next crawl under the dash and check the brake interlock. Naturally hose it with WD40. Why not right? Good luck.
    Nov 2007
    I got it. I ended up removing the cover where the boot is attached. From there I seen the pawl & was able to unlock it. Thanks for the help.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    No problem. Glad I could help.
    Matera97's Avatar
    Matera97 is offline Cadillac Owners Fanatic
    Automobile(s): '97 Catera (Ocean)
    Mar 2009
    Halifax
    31
    463
    Now do you have to do that everytime you want to drive? If so, this seems like a very temporary fix. If you come up with a permanent fix, please let us know. Thanks!
    May 2005
    66
    343
    Quote Originally Posted by Matera97 View Post
    Matera97 there is a TSB issued towards the general area of stuck key, steering unlocking, etc., which might give clues to also this problem.
    The TSB number is: 01-02-35-002 and it was issued March 12,2001.
    It basically involves cleaning up the roughness, etc., in the shifter pattern detent and shift linkage adjustment if needed.
    DIFFICULTY REMOVING KEY FROM IGNITION LOCK CYLINDER (ADJUST MANUAL SHIFT LINKAGE, INSPECT SHIFTER PATTERN DETENT LEVER)
    CONDITION
    CAUSE
    l
    l
    CORRECTION
    TECHNICAL SERVICE BULLETIN
    Reference Number(s): 01-02-35-002, Date of Issue: March 12, 2001 CADILLAC:1997-2001 Catera SECTION:02 - Steering
    Some customers may comment that the ignition key may be difficult to remove from the ignition lock cylinder at times.
    This condition may be caused by the shift lever rod not fully contacting the key release micro-switch in the shifter assembly due to one or both of the following reasons:
    The manual shift linkage may not be properly adjusted. The shifter pattern detent lever may have a burr or rough edge at the park position opening.
    Manual shift linkage adjustment should first be checked and adjusted if necessary. Inspect the shifter pattern detent lever for any burrs or rough edges at the park position opening. Use the following service procedure:
    1.Check and adjust the manual shift linkage. Refer to the Shift Control Linkage Adjustment procedure in the Automatic Transmission sub-section of the Service Manual. 2.Remove the gear selector boot from the console. The boot snaps into the console and can be removed by gently pulling up on the front end of the boot.
    3.Inspect the shifter pattern detent lever for any burrs or rough edges at the park position opening.
    4.Ensure that the shift lever rod is adequately lubricated at the base where it contacts the shift pattern detent lever.
    5.Verify correct system operation. With the key ON, engine OFF and the selector in the park position, raise and lower the shift lever rod (2 in Fig. 1 ). In its fully bottom position, the rod should contact the micro-switch (3 in Fig. 1 ). An audible click will be heard in the steering column confirming the key release lifting magnet operation.
    6.Install the gear selector boot to the console.
    ford302 is offline Cadillac Owners Member
    Automobile(s): catera
    Dec 2010
    6
    i had that issue on my 97 and the brake light switch was the problem. but if that is your problem make sure you replace it with a gm one because the aftermarket ones dont work i had the same issue a week later. after the gm one went in it has been good ever since
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Quote Originally Posted by ford302 View Post
    I got mine from oreilly auto about 3yrs ago and it still works fine.
  12. Remove Advertisements
