01 Catera turns over but won't start. Got code P1530
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, 01 Catera turns over but won't start. Got code P1530 in Past Cadillac Vehicle Discussion; My car's turning over but not starting and the check engine light came on. I scanned and got code P1530: ...
    gitcypher's Avatar
    gitcypher is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    8
    Question01 Catera turns over but won't start. Got code P1530
    My car's turning over but not starting and the check engine light came on. I scanned and got code P1530: Ignition Timing Adjustment Switch Circuit.
    Any suggestions?
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: 01 Catera turns over but won't start. Got code P1530
    Quote Originally Posted by gitcypher View Post
    Any suggestions?
    It seems to point to Throttle Position (TP) sensor as well as the throttle body movement.
    I always start with checking connectors for sensors first. Throttle body you need to verify that it is not stuck. It needs to move under the throttle control mechanism and is spring loaded to not move totally freely.
    Hope it helps as you appear to be quite knowledgeable regardless.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    They make no sense to me but maybe your smarter.
    L81 V6 Codes Chart
    http://service.gm.com/gmspo/mode6/pd.../2001file3.pdf
    Catera OBD II Mode 6 Page
    http://service.gm.com/gmspo/mode6/Ca...%20Catera.html
