Jack stand points - where?
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, Jack stand points - where? in Past Cadillac Vehicle Discussion; Can someone tell me where to place the jack stands for both front and rear support? I've looked underneath for ...
    Catera Penguin is offline Cadillac Owners Member
    Sep 2004
    9
    QuestionJack stand points - where?
    Can someone tell me where to place the jack stands for both front and rear support? I've looked underneath for a solid support point, but can't seem to locate any.
    Also, when using a hydraulic lift in the front end, where is the best place for that?
    Since I own a 97 Catera with 172k miles, I have a feeling I'll be putting it up on block a lot
    Thanks,
    Jaime
    cclark440 is offline Cadillac Owners Member
    Aug 2004
    Southern California
    32
    Re: Jack stand points - where?
    I had the same problem when I first jacked the car up.
    My '98 has been on stands for about 4 weeks now, and everything is holding up fine.
    I put the rear stands under the back side of the lower control arms. The front stands are under the frame rails just behind the front wheels. I will take a couple pictures if I get a chance.
