Power Resonator MANTZEL. Did You know about? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Cadillac Catera and Cimarron Forum Discussion, Power Resonator MANTZEL. Did You know about? in Past Cadillac Vehicle Discussion; elvin, by the way try to isolate the K & N filter tube from the hot air coming from the ...
  1. #16
    CateraIRMSCHERMv6's Avatar
    CateraIRMSCHERMv6 is offline Cadillac Owners Member
    Automobile(s): Catera
    Jun 2010
    37
    20
    Re: Power Resonator MANTZEL. Did You know about?
    elvin, by the way try to isolate the K & N filter tube from the hot air coming from the engine. I measure the acceleration without it and I was shocked. Changed only the sound and nothing else I closed my K & N filter in the original box and the filter worked better. As for multiram - noticeable increase in speeding up (speed?) Is within 3500RPM (MultiRam bottom) & 4500RPM (inside the intake manifold).
    Resonator makes the engine accelerates better from the bottom of the RPM.
    When mounted resonator, it is necessary to bypass the lower valve multiram. That's all, without any changes.
    ECU does not need programming and mapping. He learns to adapt the air - fuel.
  2. #17
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Quote Originally Posted by CateraIRMSCHERMv6 View Post
    From what you say, the Resonator increases torque at low RPM which is a good this since these engines are weak there but it also means that it reduces power at high RPM. I think the Multi-Ram is better for normal everyday operation over a wider RPM range. There are 2 valves involved. The external on on the plastic intake tubes, and an internal one inside the Intake Plenum. Their purpose is to provide different paths for the inlet air at different RPMs to optimize torque at low RPMs and HP at high RPMs..
    A long narrow path accelerates the intake air at low RPM. It's called the Bernoulli Effect. That's good for bottom end torque. But the set-up chokes the intake at high RPM and limits top end HP.
    If the intake path is short and wide you get fast air at high RPM. That's good for top end HP, but bad for bottom end torque.
    The Multi Ram allows a good compromise across the RPM range. The 2 valves combine to effectively change length and width of the intake path, at set RPM stages, to optimize the airflow into the engine. Removing it leaves you with the internal valve but without the external one the airflow will be compromised.
    An intake compressor like a turbo or supercharger shoves air into the engine so it always has fast moving air regardless of RPM. Without one, and minus the Multi Ram, the engine will suffer.
    The following diagrams are from the Omega Owners Forum:
    I know that my Air Intake is sucking hot air but I read that hot air increases an engine's fuel mileage and cold air increases an engine's power. Right now I need better fuel mileage. I have no proof but I believe the popular K&N type air intake kits can improve performance because they eliminate some intake restriction which helps the Mutli Ram do its stuff. Whether it helps power or torque or mileage I don't know, but I do know that the engine spins quicker and feels more responsive to the throttle. It also makes a growling intake sound that I like. I snatched this picture from ebay. It's not my kit exactly but close. It's about $45 USD plus shipping. The filter isn't K&N. That's $20 USD more.
    click
  3. #18
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    As everything else thats aftermarket the sellers claim that this thing increases power and thus you crazy modifiers out there must buy it...
    In other words if the folks at Opel felt that some square empty box was not good enouhg so they went throught the trouble to create extra valves and passeges and vacuum solenoids cuz I guess they were bored at work and had had nothing to do and also a bunch of research money they had to blow away anyways.
    I have tried the airbox on/off and a custom pipe that goes from the MAF to the throtle bodies and in both cases found power to go down in various spots of the power band...
    So I stuck with teh OEM design and I am happy with how and where it makes power.
    Now I am sure this box will probably have a sweet peak somewhere at say 3000rpm or higher but in my book the stock system is sufficient for our needs.
  5. #19
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Quote Originally Posted by CateraMV6 View Post
    I am sure this box will probably have a sweet peak somewhere at say 3000rpm or higher,...
    You can make a sweet spot with some cheater juice right about then too!
  6. Remove Advertisements
