New here/Where to add Trans Fluid
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, New here/Where to add Trans Fluid in Past Cadillac Vehicle Discussion; Seeing that there was not Dip Stick. Where on the car could it be replaced? And if so would anyone ...
    Daddyof3 is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Catara
    Jun 2010
    36
    3
    Seeing that there was not Dip Stick. Where on the car could it be replaced? And if so would anyone have a picture to help provide me?
    Thank you!
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Re: New here/Where to add Trans Fluid
    It's a sealed unit, but if you crawl under the car towards the transmission pan area you'll see a bolt on the side of the pan (passenger side). That's the only place you can fill the fluid up.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Not exactly a how-2 on topping off the transmission but close enough.
    http://www.vauxhallownersnetwork.co....(and-a-2-litre)
    Sep 2007
    1,024
    I just used a hand siphon pump and filled my transmission when it was low. What I did was, jacked the car up and send the one end of the siphon hose into the bolt hole then lowered the jack down. Then I kept the transmission fluid bottle high and siphoned it down to the pan.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    36
    449
    If you go to a transmission shop and tell them that its a fill untill tranny they have a seringe type tool that pumps it in.. fill.. unitill! lol.. this is the dumbest thing ! they should have left the dipstick!... I found this out the hard way. what an ordeal.. the mech ended up fileing down the tip on an air hose threading it into the hole and dumping the fluid in!
  8. Remove Advertisements
