1998 Catera DTC PO501 Vss 'A'
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, 1998 Catera DTC PO501 Vss 'A' in Past Cadillac Vehicle Discussion; 98 Catera speedometer/odometer not working. TC/ABS lights illuminated. DTC PO501 vehicle speed sensor 'A' range/performance code. Where is this sensor ...
    mbcad is offline Cadillac Owners Member
    Automobile(s): 98 Catera
    Mar 2009
    Where is this sensor located, and is there anything else I should check/test before replacing this sensor?
    michaelg1989 is offline Cadillac Owners Member
    Automobile(s): catera
    Jun 2010
    1
    Re: 1998 Catera DTC PO501 Vss 'A'
    i also have a similar problem my speedometer and my rpm gauge work about 30% of the time the rest of the needl;es just sit there n bounce
    Kodan is offline Cadillac Owners Member
    Automobile(s): Opel Omega Limousine 3.2 Executive | 2003 | Automatic.
    Oct 2008
    The Netherlands
    99
    The ABS module delivers the speedsignal.
    The sensors are located on the rear off differential.
    You can check if the ABS module is working correctly.
    Any ABS warning lights?
    Peter
    Mar 2009
    Peter, The traction control and ABS light are both on.
    Oct 2008
    The Netherlands
    99
    Then you have a malfunction in the ABS/TC module.
    Could be a sensor, there are four, two near the differential en one at each front wheel or the ABS ecu or just a bad connection plug.
    Could be the plug on the ABS/TC module itself that makes a bad connection.
    Go to a dealer and let them read out the ABS/TC with a Tech2.
    There is no speedimpulse If the ABS/TC is does not working.
    Peter
  8. Remove Advertisements
