OMFG Help!!!! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Cadillac Catera and Cimarron Forum Discussion, OMFG Help!!!! in Past Cadillac Vehicle Discussion; Make sure you have the tensioner down as far as you can get it, and i always slide it on ...
  1. #16
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Re: OMFG Help!!!!
    Make sure you have the tensioner down as far as you can get it, and i always slide it on the w/p last, as it doesn't have a lip or groves. Make sure it's sitting nice in all the other pulleys to give you a little more slack.
  2. #17
    Matera97's Avatar
    Matera97 is offline Cadillac Owners Fanatic
    Automobile(s): '97 Catera (Ocean)
    Mar 2009
    Halifax
    31
    463
    Re: OMFG Help!!!!
    Well see thats the thing, the tensioner won't move...Or I'm not sure how to move it I should say (first serp belt replacement). I guess to afraid to brake anything else in the process.
  3. #18
    fuzzkill is offline Cadillac Owners Member
    Automobile(s): Catera
    May 2009
    37
    Re: OMFG Help!!!!
    Put the box end of the wrench or ratchet over the bolt holding the pulley on. It will spring one way giving more slack so you can slip on the belt and then remove the wrench.
    I don't think it's reverse thread on these cars ... but just put the wrench on like you were going to tighten the bolt and it should spring over. If it doesn't move freely or doesn't spring back on its own you might need to replace the tensioner assembly. Which is pretty simple as well, just 2 or 3 bolts.
  5. #19
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: OMFG Help!!!!
    well, I know the actual shank with the threading, springs in and out. but I was unable to move the pulley itself. Maybe just not applying enought pressure. Well, anyways my day was ruined by spring downpours. will be back at it tomorrow.
  6. #20
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: OMFG Help!!!!
    All right, so first off, was using wrong tool for moving tensioner, 7" ratchet. Changed to the braker bar, tensioner moves. So than I ran into a problem that the part store gave me a common 3.0L GM/Saab belt. Was about an inch to short, got the right one, took 10 min to install.
  7. #21
    AwfulSmokey is offline Cadillac Owners Fanatic
    Automobile(s): 99 Catera
    May 2006
    Ft Myers, Florida
    157
    Re: OMFG Help!!!!
    Glad to see you got it done with minimal issues.
  8. #22
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: OMFG Help!!!!
    Yeah, its my first ever serp install so I guess it went okay, probably take me 30 min in total to do it again. The air injection crossover pipe is the biggest pain, always in the way, and the compressor hose support is a pain getting to, but all in all once you've done it, its actually a small job. I'm not sure how much more difficult it would be on a 2000+ model with the extended plenum. Probably the same!
  9. #23
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Re: OMFG Help!!!!
    Quote Originally Posted by Matera97 View Post
    Matera I am little stuck on my 2001 Catera base model. I need to replace the serpentine belt. I want to do it without getting under the car.
    If you were able to do it this way can you please provide 1, 2 or 3 steps what you disconnected and where. I cannot disconnect the Bracket from the alternator bolt from above and alternator bolt and screw is seized pretty tight.
    Thank you.
  10. #24
    May 2005
    66
    343
    Re: OMFG Help!!!!
    No worries I changed the serpentine belt yesterday by getting under the car and removing the plastic shield under the front. Two nuts need to be removed to allow the belt to bypass the secondary air injection pipe and the AC piping. On a second time around it will be tops 30 minutes for me.
    By the way I installed an overdrive generator pulley (1.7" versus the standard 2.21" to improve the idle performance for the generator/battery under fan loads (the cooling fans for the radiator and the cabin blower motor). I know it may rob me some power but haven't noticed much yet. When more complete results I will document for others consideration if they choose. I had to use a slightly shorter serpentine belt to cover for smaller pulley.
    Regards.
  11. #25
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: OMFG Help!!!!
    Yeah, I think that was the belt that I originally purchased. But because I put the original pulley on, I needed that extra 3/4" of belt length.
  12. #26
    HoffmansCaddi is offline Cadillac Owners Member
    Apr 2010
    42
    9
    Re: OMFG Help!!!!
    The belt autozone had wouldnt fit my car. It looked like the grooves where too deep to fit into the grooved pulleys. I got a Napa one and it fit fine?
  13. #27
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: OMFG Help!!!!
    There are at least 2 different belts for the GM 3.0 L81. The differences are the tracks, length, and cost. The actual one for the catera is like $20 more. lol
  14. Remove Advertisements
