Brake upgrade - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 91
Cadillac Catera and Cimarron Forum Discussion, Brake upgrade in Past Cadillac Vehicle Discussion; My pads didn't even come with clips, so you may not even need them....
  1. #46
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Brake upgrade
  2. #47
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,025
    Re: Brake upgrade
    I got the GTO pads from autozone and they fit perfectly, the corvette c5 has a different hardware for the ends and the center piece.
  3. #48
    Sep 2007
    1,025
    Re: Brake upgrade
    Does the bleeder valve have to stay on the bottom or top? Does it matter which way the bleeder sits? Please let me know about the bleeder valve. I did one side and will finish the rest tomorrow.
    I'm also having trouble with the end plate on the brake hose. The one on the catera (right side) is welded to the body so could not get it out so I had to use a cable tie and secure the GTO one on top of the old one. I hope that will be fine. Also, in the middle of the hose does the rubber / plastic piece slide into the metal plate to be secured, this is by the shock area because I'm having trouble sliding that in.
  5. #49
    Matera97's Avatar
    Matera97 is offline Cadillac Owners Fanatic
    Automobile(s): '97 Catera (Ocean)
    Mar 2009
    Halifax
    31
    463
    Re: Brake upgrade
    More pictures of an installation here
    http://cateraowners.forumotion.com/b...wap-t5.htm#713
  6. #50
    Sep 2007
    1,025
    Re: Brake upgrade
    I guess it doesn't matter which way the bleeder valve sits. Now I need figure out how to secure the brake hose to the metal hook by the shock.
  7. #51
    Sep 2007
    1,025
    Re: Brake upgrade
    Does anyone else know if the bleeder valve has to stay on the top or bottom? I saw the pictures from previous posts and could not tell if the bleeder valve was on the bottom or top.
  8. #52
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Brake upgrade
    TOP TOP TOP, the bleeder valve needs to be on the top! When you bleed your braked you're getting the air out of the system, bubbles float to the top, so you need it at the top.
  9. #53
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Brake upgrade
    Quote Originally Posted by retho78 View Post
    I don't completely understand what you're asking here.
  10. #54
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Brake upgrade
    These are from when I was doing mine.
  11. #55
    Sep 2007
    1,025
    Re: Brake upgrade
    The hose I have is the orignal GTO ones and it has a metal plate that is on the end of the hose where it hooks up to the brake line that goes into the ABS (I think). I could not get that metal peice out and the one the catera is welded to the frame body. So I had to use a cable tie and secure the plate on top of the catera's brake hose plate and the hook up the ABS line to the brake hose. I may have to take a picture so you guys can see what I'm talking about.
    I have installed the caliper and the new rotor on the left side and the bleeder valve is on the top but for the right side when I looked at the caliper it looks like the bleeder valve is going to be on the bottom. Any ideas what could be the problem?
    Thanks.
  12. #56
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Brake upgrade
    Yes, i remember now. The calipers are the exact same so left is right side up and right is up side down. When you bleed them just pivot the caliper (like if you were changing brake pads) up with the upper mounting bolt loosened but still in. Are you talking about that plate in the back of my 2nd picture? I just snugged mine in there too, but i was able to get it tight by moving this here and that there, but a zip tie would have done the job.
  13. #57
    Sep 2007
    1,025
    Re: Brake upgrade
    I see that center plastic piece on yours is different than the one I have. Mine looks round and is a bit bigger in diameter so is hard to slide into the metal peice to secure it. I may have to try like how you did on the end of the hose (metal plate) and secure it properly.
  14. #58
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: Brake upgrade
    I'm just wondering, are the fittings for the brake hose and the bleeder the same size and threading. Isn't it possible to switch the two?
    Actually from what I can see of MV6's installation, his hoses are in the same position. So the threading is the same, so you should be able to switch sides.
  15. #59
    Sep 2007
    1,025
    Re: Brake upgrade
    Yeah, it will fit but the catera's brake hose is few inches shorter.
  16. #60
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Re: Brake upgrade
    I'm not talking about the catera hose, I'm talking about switching the hose and the bleeder's positions, if its possible. From looking at MV6's install the hoses are at the bottom of the caliper on both sides and the bleeders are on the top. If its not possible to switch the bleeder and hose position, than you and Hazzard got two left side calipers!
  17. Remove Advertisements
