drilled and slotted rotors
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, drilled and slotted rotors in Past Cadillac Vehicle Discussion; i found these on ebay, drilled and slotted rotors ! i bought some rotors for my focus from the same ...
    freestyla is offline Cadillac Owners Member
    Jul 2004
    26
    i found these on ebay, drilled and slotted rotors ! i bought some rotors for my focus from the same guy a couple of months ago, and they're pretty good quality. my question is that i have to get new pads and rotors on all four, so can this switch to performance rotors be easy. i read in this other thread that when this guy had his brakes done, he had to buy new sensors, would these senser work on these rotors? i hope its just an easy switch like my focus!
    rollincatera's Avatar
    rollincatera is offline Cadillac Owners Member
    Aug 2004
    madison, wi
    81
    Re: drilled and slotted rotors
    not sure how it works...i actually just bought some myself about 2 weeks ago...still awaiting the shipment so I can put on the new performance pads with the new rotors all the way around. i'll be posting pictures of those, my new intake(no-name brand off ebay, $30, kick ass sound) i installed today and the 18's that i'm also still awaiting.
    i also bought one of those "headlight renew" kits that takes off the yellowish/colorized crap that builds up on your headlights...
    it only cost $4.99 and that was With the shipping. guys, this stuff actually works... of course it doesnt work as good as their pictures show(maybe i just dont know how to use the stuff correctly) but it made my headlights look 75% better/newer. for the cost i'd suggest getting this stuff if your concious about how your catera looks
    _hp_ is offline Cadillac Owners Member
    Apr 2004
    32
    Unless your brake pad wear light came on you shouldn't need new sensors.
    Jul 2004
    26
    so then it should just be a simple swap like any other car?
    Jul 2004
    26
    anyone, please help!
    Apr 2004
    32
    Yes. Unbolt the bolt on the caliper, raise the caliper, take the old pads out. The sensor will be on the inner sensor, be careful when unplugging it, and then just put in the new ones.
    valle1018 is offline Cadillac Owners Member
    Jul 2004
    49
    Do you have to replace the sensors when replacing the rotors and the pads??
  10. Remove Advertisements
