Catera Head gasket?
Results 1 to 10 of 10
Like Tree1Likes
  • 2 Post By retho78
Cadillac Catera and Cimarron Forum Discussion, Catera Head gasket? in Past Cadillac Vehicle Discussion; Hi, If the head gasket is blown will it cause the coolant to leak or just oil? And how easy ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Catera Head gasket?
    Hi,
    If the head gasket is blown will it cause the coolant to leak or just oil? And how easy is it to replace head gaskets?
    Any step by step instructions and illustrations?
    Thanks.
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    Re: Catera Head gasket?
    Yep, if your headgasket goes, coolant and oil will mix in the combustion chambers.
    You should see white smoke out of the tail pipe, white spark plugs, and fouled oil and coolant..
    Most likely its the oil cooler on the engine.
    Sep 2007
    1,024
    My anitfreeze is leaking and haven't seen any white smoke coming out of the tail pipe. At first I had the oil and anti freeze leak so I replaced the oil cooler last week, drove it around for about 40 minutes and still having the anitfreeze leak. I'm going to do a pressure test and hopefully find out what the problem is.
    Any step by step instructions and illustration to replace the head gasket, if in case I need to replace them.
    Thanks.
    charliePark and charliePark like this.
    Sep 2007
    1,024
    When doing the coolant pressure test, do I fill it up with anitfreeze / water or something else to find out where the leak is coming from?
    catera00's Avatar
    catera00 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Feb 2007
    Tucson, Az
    40
    390
    Quote Originally Posted by retho78 View Post
    You can get dye and a black light from autoparts stores but you should be able to see it pissin out from the leaky spot when you pressurize it. What year is your catera. I think head gaskets were more of a problem for pre-facelift engines. Also when my 2000 had a bad head gasket, I had no external leak or oil mixing with coolant. Damn cateras. Such pains to diagnose sometimes.
    Sep 2007
    1,024
    I have a 98 catera and about 94K miles on it.
    TitanCTS's Avatar
    TitanCTS is offline Cadillac Owners Fanatic
    Aug 2003
    Watertown, MA
    32
    199
    First off you need to be sure to find where most of your coolant is leaking, In your case you still think it's the oil cooler or the head gasket, correct? Sometimes a headgasket leak will not leak into a cylinder or mix with the oil, Some HG leaks will leak coolant externally only. When using the pressure tester be sure to pump the system up to a maximum of 30psi, anything lower than that if the leak is small enough will not leak out. 30 psi is maximum system pressure. Try not to dilute the coolant mix with water too much. Too much water will cause the block to scale and rust which will deposit inside your heater core and cause blockage preventing your heater from working properly, I've seen this issue so many times on Audi's when people think they can mix water into the coolant and find out their heater core and/or radiator is plugged. Also try to use all the same Dexcool coolant and not the mix with any antifreeze crap coolant. Prestone sells 50/50 premixed dexcool coolant which is good stuff. If you purchase straight coolant concentrate and it needs water added to it, be sure to use distilled water, ordinary tap water contains impurities which will cause the same issues as I stated above.
    Robotdoogie is offline Cadillac Owners Member
    Automobile(s): '97, '98 Catera
    Feb 2009
    Canada
    5
    Also check the heater control valve behind the right hand cylinder head. This can leak and look like a head gasket problem. The valve is $100 verses the cost to pull a head. Just an FYI.
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    if you work on one of these cars you must have books
    kaustein is offline Cadillac Owners Enthusiast
    Jul 2008
    712
    Quote Originally Posted by Robotdoogie View Post
    I had the same issue and the freakin' scumbag dealer told me that it was a head gasket for $1800. So my subbie tech friend checked it and replace the heater control valve. Works fine now, however I still have the other million little electrical problems. Just hoping the car catches on fire!
  13. Remove Advertisements
