Radio Problem
Results 1 to 13 of 13
Cadillac Catera and Cimarron Forum Discussion, Radio Problem in Past Cadillac Vehicle Discussion; Just bought a 2000 Catera and the radio has intermittent operation. It comes on when I start the car, but ...
    itten1 is offline Cadillac Owners Member
    Automobile(s): Catera
    Feb 2010
    Radio Problem
    Just bought a 2000 Catera and the radio has intermittent operation. It comes on when I start the car, but while driving it'll cut off and then cut on again. I checked the fuse and re-seated it. I'm thinking this is a connection problem. Does anyone have any ideas as to what I can do short of taking in for service. I would imagine it would be hard to trouble shoot if the radio is on when it is checked. Email me if you can: itten@comcast.net
    Thanks.
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    Re: Radio Problem
    K134 Relay under the driver side footwell if you look above the hood release knob, straight up, you will see it its grey a bit smaller then a box of cigarettes,
    Open that and look for broken solder points... thats what causes the issues...
    I am 100% sure that this is the problem you have.
    CateraMV6's Avatar
    Oct 2006
    Dearborn MI
    1,419
    Re: Radio Problem
    The relay you need, inside there are various items that control the vehicle...
    http://www.cadillacforums.com/forums...light-fix.html
    2000Cat is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    Jan 2010
    38
    19
    Re: Radio Problem
    +1 Check it for cold solder joints.
    TitanCTS's Avatar
    TitanCTS is offline Cadillac Owners Fanatic
    Aug 2003
    Watertown, MA
    32
    199
    Re: Radio Problem
    Anyone have the part number for the K134 module?
    CateraMV6's Avatar
    Oct 2006
    Dearborn MI
    1,419
    Re: Radio Problem
    Quote Originally Posted by TitanCTS View Post
    I snatched an extra relay from a junked catera, so I will look at it tomorrow and post that info for you!
    MRXRAY is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Feb 2010
    49
    14
    Re: Radio Problem
    Would this hold true for the 1998 Catera as well?
    CateraMV6's Avatar
    Oct 2006
    Dearborn MI
    1,419
    Re: Radio Problem
    I think all cateras suffered from the K134 relay, the second one I got, I found a few joints that had very little cracks and as soon as I touched them with the iron, a major void opened underneath revealing absolutely no solder to hold the connection.
    When that heats up it expands and often cuts out the circuit. Carefully inspect them all and make sure none of them are showing cracks.
    Feb 2010
    49
    14
    Re: Radio Problem
    Any Idea where the K134 relay module is located on a 1998 Catera?
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Radio Problem
    Lizzys Cat is offline Cadillac Owners Member
    Automobile(s): 2000 Catera!
    Aug 2013
    10
    Re: Radio Problem
    If you are having the radio issue where it won't power on in position 2 and only key position 1 upon shutdown, check fuse #10 for the aux water pump. This was our issue and not the K134 MF relay.
    tris is offline Cadillac Owners Member
    Automobile(s): none
    Jul 2014
    none
    1
    Re: Radio Problem
    how do I reset my computer I just got a new ignition switch put in with a new
    key.
    __________________________________________________ ______________
    Good afternoon, Your CF account is activated. Please update your profile to show correct information and time zone - or do you really live in London - GMT ?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    key have to be programmed in to ECM. no way u can do it. tow it to the dealer.
    I had samething when I replaced ECM. it wouldn't start cuz ignition switch is different. My mechanic had to reprogram ECM for new Switch
  16. Remove Advertisements
