Removing rear panel on trunk
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, Removing rear panel on trunk in Past Cadillac Vehicle Discussion; Im looking to remove the rear trunk panel (piece between rear lights that has the badge and catera nameplate on ...
    Dtz7635 is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Jan 2010
    5
    QuestionRemoving rear panel on trunk
    Im looking to remove the rear trunk panel (piece between rear lights that has the badge and catera nameplate on it) on a 2000 catera so i can do some body filling and painting... im re-badging the car to an omega... im assuming this should be pretty easy, just remove trunk liner and unscrew... if there are any tricks to it please let me know, im not going to start the project for a little while... no time! thanks
    Cadi Cat is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera
    May 2005
    Michigan
    32
    314
    Re: Removing rear panel on trunk
    Is it just that easy? Remove liner and unscrew? I'm looking to resurface and repaint next week. The clear coat is peeling off from the top down.
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Yes, just remove the liner but make sure you don't break any of that plastic screws that hold the liner. Once you are through with the liner, there are few bolts and then the two bulbs.
