Airbag Alarm Light
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, Airbag Alarm Light in Past Cadillac Vehicle Discussion; This morning I started my 2001 Sport and the dash went through its routine. All the idiot lights went out ...
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Airbag Alarm Light
    This morning I started my 2001 Sport and the dash went through its routine. All the idiot lights went out except for the Airbag light. I'll check my manuals when I get home but in the mean time, does anyone know what it means and how to extinguish it?
    Matera97's Avatar
    Matera97 is offline Cadillac Owners Fanatic
    Automobile(s): '97 Catera (Ocean)
    Mar 2009
    Halifax
    31
    463
    Re: Airbag Alarm Light
    My light has been on since I bought my car. My light represents the passenger air bag (I think), and I'm pretty sure I read that it is an electrical issue, not so much a functional issue. Thats all I can remember.
    Kodan is offline Cadillac Owners Member
    Automobile(s): Opel Omega Limousine 3.2 Executive | 2003 | Automatic.
    Oct 2008
    The Netherlands
    99
    There could be a lose or bad contact on one of the airbags or the seatbelt tensioners or just a one time hick-up.
    If the airbaglight is on the system is not working will not not deploy when you have a accident.
    Only the dealer with an Tech 2 can identify where the problem is and reset the system.
    The common errors of the spontaneous airbaglight are the connection of the seatbelt tensioners.
    Peter
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    In my case it's not a one time occurrence. The light is constantly on. I'll check the seatbelt connector if someone can tell me where it is. I looked for it but admittedly without a flashlight in my poorly lit garage. Is it under the seats? I have a 2001 with side airbags in the front seats. Could it be those too?
    Oct 2008
    The Netherlands
    99
    The airbag lights stays on until it is reset with the Tech 2.
    The dealer could tell you where the problem is.
    If you removed any airbag connectors (door or seat) with the ignition on or turn the ignition on after you removed any airbag connectors the light will come on and stays on.
    The connector is where the "X" is.
    Remove the plastic cover (arrow).
    "A" is where the seatbelt and power and seat heating connectors are.
    "B" is the side airbag connector, is connected on the side of the "A" conector.
    Peter
    49mill is offline Cadillac Owners Member
    Aug 2014
    1
    Hi, I have managed to break the airbag connector for the seat airbag and Carn't work out which way round the wires go. I have a 2003 omega mv6 rhd,and it's the passenger side wiring that I have broken. Do you have any pictures of the wiring connectors so I can worn out which one goes where.
    Would really appreciate it.
    Thanks
    marcospedraza is offline Cadillac Owners Member
    Automobile(s): 2001 Catera Sport,2008 STS-4
    Aug 2014
    6
    op-com reads and clear Airbag codes.I cleard 5 codes out of my 01,the trick was that I have to use 98 Omega B Airbag SAB6
  10. Remove Advertisements
