Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Coil Pack Remover
Old 11-06-09, 10:23 AM
Cadillac(s): Catera
View Grump's Photo Album
Casino Cash: $370
Coil Pack Remover
Just picked up a 99 Catera 2 days ago and would like to change the plugs since the PO had no idea when they were last changed. Subscribed to ALLDATADIY since I could not find a repair manual locally. ALLDATA says tool J43301 is required to remove the coil pack. Any suggestions on a source for this tool and is there an alternative way to remove? When I belonged to an other make forum, they had a loaner agreement where as you could borrow a specialty tool from another member, just pay shipping both ways. Anything like that here? It saved a lot of unnecessary expense since most specialty tools we very seldom used. Thanks...Bill
  #2 (permalink)
Old 11-07-09, 07:02 PM
MyOpel's Avatar
Cadillac(s): 2001 Catera Y57XE
View MyOpel's Photo Album
Casino Cash: $9392
Re: Coil Pack Remover
don't need it
but you do need torx socket (star shaped bolt)
2 bolts one plug and it's out
drivers side you need to move the wire harness and unscrew the oil fill tube by lifting the tab on the valve cover and then 2 bolts one plug and its out
platinum plugs don't need changing till 100k+ miles (factory is platinum)
  #3 (permalink)
Old 11-07-09, 07:23 PM
AHazzardToAll's Avatar
Cadillac(s): 1999 Catera Sport, 1967 Olds Delta88, 1989 Merkur Scorpio
View AHazzardToAll's Photo Album
Casino Cash: $4610
it sounds more complicated than it really is. you just have to move the harness to one side with one hand as you pull the coil off wiht the other(after removing mounting bolts of course.) i didn't even have to move my oil tube but it is simple and would make removal much easier.
  #4 (permalink)
Old 11-07-09, 08:16 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
If you can find the right size bolt to thread into the holes, it should be fine.
You just need something to hold on to while you pull them straight up.
Don't pry on them or you'll start breaking pieces off.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #5 (permalink)
Old 11-08-09, 09:45 AM
Cadillac(s): Catera
Casino Cash: $370
Thanks for the info. Good to know that the $98 tool is not necessary...Bill
coil, pack, remover
