98 Catera starting problem
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, 98 Catera starting problem in Past Cadillac Vehicle Discussion; My wife took her car to the store and when she tried to start it it wouldn't. It would not ...
    Davejk is offline Cadillac Owners Member
    Aug 2004
    Unhappy98 Catera starting problem
    My wife took her car to the store and when she tried to start it it wouldn't. It would not turn over, no sound, nothing. The horn and the door locks would work. After a bit over an hour she tried it again and it started no problem. It was hot, low 90's. About 6 months ago it would turn over but not start. The dealer could not find any problem.
    Does this sound like the crank or cam position sensor? Would that stop it from turning over? Any other ideas?
    Thanks in advance.
    Dave
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: 98 Catera starting problem
    We had the same problem, it got worse and would stall out while driving and not restart.
    In our case if i remember correctly, it was the cam sensor(s).
    ZiaBD4 is offline Cadillac Owners Member
    Automobile(s): Catera, Allante, XLR
    Mar 2004
    Espanola, New Mexico
    65
    9
    We had the same problem with our 98 Catera. The dealer wanted to install a fuel pump, turned out to be the crank position sensor. Located near the oil filter, one bolt, 15 min to change, and $110 part from GM.
    Aug 2004
    Actually it turned out to be a bad battery. I think those are strange symptons for a bad battery. Oh well, it has been running fine for a couple of weeks now.
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Huh.. ok... lol
  8. Remove Advertisements
