Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 36
Thread: Installing Kenwood into '01 Catera with factory BOSE using GMOS-06
  1. #16
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Installing Kenwood into '01 Catera with factory BOSE using GMOS-06
    PS: I had no issues with arms not reaching or ash tray opening. My ash try works just like new.
  2. #17
    Jun 2007
    Mooresville, IN
    26
    677
    Quote Originally Posted by JRomano View Post
    I'm installing a Kenwood KDC-MP342U into my '01 Catera. I scrounged around for the best deals on the adapting kit pieces.
    .....<filler>......
    And it looks like it matches right up here...
    I LOVE how that wiring/installation/instruction manual had directions for jap and non-jap cars. Ha ha ha.
  3. #18
    JRomano is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac Catera
    Nov 2008
    11768
    33
    144
    Quote Originally Posted by AHazzardToAll View Post
    Trust me, it was a clusterf*** wiring that thing, to top if off, the constant 12V isn't constant so I lose all my presets every time I turn the car off and more than 5-10 minutes pass. It was such a whore stuffing the 5lbs of wiring into the dash opening that I have yet to take it all back out to troubleshoot, plus its been pretty cold here for months now. Oh and the ashtray rubs against the bottom of the trim panel pretty hardcore, good thing I quit smoking or I'd go nuts dealing with that thing.
  4. #19
    Jun 2007
    Mooresville, IN
    26
    677
    yeah, ran into the same wiring issue as u. I ended up almost re-wiring everything but all works well now!
  5. #20
    MRXRAY is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Feb 2010
    49
    14
    Thanks for the write up, looks great! Going to order my kit from Crutchfield this week.
  6. #21
    Feb 2010
    49
    14
    Quote Originally Posted by eastsidercaddy View Post
    I like the fact that people are upgrading from the ancient sound system GM put in our cars... best thing is i'm putting in a set of 15's with 2400wRMS total output with both subs and a 2500wRMS amp at 2 Ohm. With this im removing my old subwoofer setup and installing the new one. Cars with BOSE need to have the sound processor removed and have wires bypass the sound processor to go directly to your speakers. The small amp, however, can easily be used to amp all speakers with your new headunit!
    PART ONE:
    THIS STEP IS TO BYPASS THE SOUND PROCESSOR AND AMPLIFIER>>>> IF YOU WANT YOUR SPEAKERS AMPED WITH YOU NEW HEADUNIT SKIP TO PART TWO....
    Here's all the pinouts and information you'll need to make a simple and hopefully quick sound system installation. This picture here is needed to identify the locations of certain wires, due to the fact that there are 3 or 4 wires of the same color. All you need to do is simply mark the wires from the SOUND PROCESSOR INPUT and find the wires for the AMP OUTPUT, from the AMP. All the speakers are amped, so you will need to find the OUTPUT wires from the amp and crimp them to the INPUT wires on the SOUND PROCESSOR. Simple installation.
    PART TWO:
    THIS PROCESS WILL ALLOW YOU TO HAVE YOUR NEW HEADUNIT AND HAVE THE FUNCTION OF THE FACTORY REAR AMP. HAVE NOT TESTED HOW THIS WILL SOUND BUT MAY SOUND GREAT. ALL SPEAKERS ARE AMPED WITH THIS.
    Now, the small amp can be used to power all of your speakers. What you need to do for this is take the SOUND PROCESSOR INPUT wires and mark them. Next, find the AMPLIFIER INPUT wires and crimp them together with the corresponding wires. Now, take the SOUND PROCESSOR DIAGRAM and locate PIN B1 and crimp that to PIN 25 on the AMPLIFIER ENABLE INPUT on the amp. This will turn the amp on when the radio is on, allowing you to have not only your headunit's internal amp working but also have the stock amp working inline to have all you speakers pumping out sound.
    If you have any questions pleas ask and i WILL help you to the best of my knowledge. Thanks
    I've read through this instruction a couple of times, and I must say it's about as clear as mud. Could yo possibly clarify this with some pin numbers?
  7. #22
    coc_diesel is offline Cadillac Owners Member
    Automobile(s): 01 Catera
    Feb 2010
    46
    1
    I needed the Metra 99-2004 dash fit kit, the Metra GMOS-06 harness kit to use the OEM Bose amp and speakers, and an antenna adapter.
    I ended up buying the GMOS-06 used on ebay, previously used in another installation. In going over the harness and see what and where I need to splice, there is a wire that looks cut. On one side of the adapter, there is a 16-pin plug, there are two black wires coming out right next to each other, one of them is cut and 2" long, the wire coming out next to it goes to another plug but at the base there is a small stub of another black wire. I want to know if these are the same wire that was cut in half accidentally upon removal. I took a few pics, let me know what you think...
    If anyone works in an audio store and you have this kit in stock, can you please report back what the plug looks like fresh out of the box? Thanks
    Heres the adapter
    Heres the loose wire
    Both the black wires are grounds. That wire on my kit is cut as well. Can't remember if I cut our not though. Hope this helps you
  8. #23
    Matera97's Avatar
    Matera97 is offline Cadillac Owners Fanatic
    Automobile(s): '97 Catera (Ocean)
    Mar 2009
    Halifax
    31
    463
    So I'm assuming that B1 (Red Wire to K134) is supposed to be constant. But where would the ignition wire go? Also I have no illumination on my deck when trying to install. I figured wiring would be easy as I'm running non-bose. But wiring colors and everything are not the same as previous decks I've installed. Anyone tell me why I have some power, as deck will take and eject discs, but no playback, no sound and no illumination?
  9. #24
    Jun 2007
    Mooresville, IN
    26
    677
    try flipping you lights on, you may have spliced your remote/acc on into the illumination from the stock wiring, otherwise it's just your rem line. i re-ran a new constant and remote from the fuse panel.
  10. #25
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Hazzard, just wondering, what fuzes did you run the wires from? Did you incorporate power from K134? As for the OEM harness, there are 2 constant power sources. Red from K134 Pin F1 as well as a Green/Grey wire from Fuze 26 Pin F4. Why the two contants?
  11. #26
    Jun 2007
    Mooresville, IN
    26
    677
    My remote came straight from the acc fuse under the dash, and i ran a new pwr from a true constant.
  12. #27
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    True Constant??? The battery??
  13. #28
    Jun 2007
    Mooresville, IN
    26
    677
    I used an existing one, but I'm not sure which one. One from the battery would work too. I think the one i used was a "PWR" fuse but I'm not sure.
  14. #29
    Matera97's Avatar
    Mar 2009
    Halifax
    31
    463
    Well I just had some mild success! The illumination signal only comes on when the side markers are on or if the lights are on. This is the same for Pin F4. The constant, ground and speaker wires were the only ones that I didn't change. So I have Illumination at E5 and ACC at F4. So I'm getting play back and lights and everything. Its a temporary fix until I can muster enough courage to tear out the fuze panel and run a new ACC.
  15. #30
    Jun 2007
    Mooresville, IN
    26
    677
    If you run your constant for the yellow stock bose "constant" then you're going to loose all your presets and settings. It onlu stays on for about 5min after you turn the car off. I've thought about actually using it as my acc in at one point, but if i did that i would have killed my battery with all the power going to my amp.
  • You may not post replies
