There is only one that I know of. I haven't had any problems with it, some some other have. I just looked under the hood. Looks like in order to remove it, you will have to take the breather hose off, unbolt the wiring bundle from the left side of the plenum, unbolt the A/C line holder bracket. I guess you're pretty much there.
I have fitted the under-hood compartment to my specs
Wire loom, no zip ties, different bolts, uncluttered and easily accessible important stuff. Most of which was done when I was putting the heads back on it. So telling someone how-to under the hood is not necessarily easy.
Good luck
