Originally Posted by TitanCTS How the hell do you get 27MPG... I can't get that for the life of me... My best managed mpg on the highway is 20mpg.. What is your secret??????  |
Well I think there were 2 things that greatly affected the MPG...
1. Driving at night when the air is dense and around 60°F which helps with slighly better fuel efficiency.
2. Driving at 65mph the entire way which actually helped a lot... the vehicles most efficient aerodynamic speed is in the 60-70mph Range so if you stay light on the throtle you will be just fine.
On my trips to Chicago I drive 75-80 and the MPGs are around 23...
Also the engine ran at no more then 30% Load the entire way... with mostly cruise driving.
3. No use of A/C or any other power consumers. (just headlights)
4. Keep tires pumped to around 38psi which is the recommended for high speeds. That helps with rolling resistance as well.
Thats how I did it!
