| 88 Cimarron Starts and Stalls. Help! I need some help with this because it is killing me! I have a 88 Cimarron that starts when cold but when it warms up or is driven a short distance, it will stall. If you try to start it again it will run for a minute then sputter and stall again. After a few starts, it will not start anymore unitl it has had time to rest. Then it will run again for a short time. I have relpaced a bunch of parts including the ECU and crank sensor but the problem stays. I have had this problem in the past and it was solved with a new ECU, but it does not seem to be the problem at this time. Please help! |
