Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: No interior lights..
    todderdodder1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    29
    29
    Would anyone have any lead-way as to where i can start looking for a reason why i have no interior lights.. The lights in the doors, the lights in the roof and even the map lights.. none work. Any help would be greatly appreciated!
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: No interior lights..
    Try Multifunction Module
    Nov 2008
    29
    29
    already did.. got nothing...
  5. #4
    R-Caddy's Avatar
    Jul 2005
    Savannah, GA
    32
    698
    fuse?
  6. #5
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    I just read Knockout's thread where he said that pulling the Onstar fuse killed the dome and interior lights. You might want to check that.
  7. #6
    hooked up is offline Cadillac Owners Member
    Automobile(s): catera
    May 2009
    scranton pa
    40
    10
    well i have a 97 without onstar and i have no interior lights either all though sometimes they kick on any idea why
  8. #7
    Nov 2008
    29
    29
    yeah, my 98 doesn't have on*star either... every fuse i could find (under drivers knee panel and under hood around battery) is good.. i even replaced some that i thought were not "optimal" and im sure its not the door switches because the little lights in the window switches turn off properly when i open the door.. also the power windows will work with the key off untill you open the door.. any other ideas??
  9. #8
    eastsidercaddy's Avatar
    eastsidercaddy is offline Cadillac Owners Fanatic
    Automobile(s): '97 Black Catera
    Jan 2008
    Jacksonville NC
    27
    210
    you have to get under the drivers side dash where your fuse box is and remove the heater/ac vent plastic. Once you do that get a flashlight and look for a medium sized grey box next to some red relays. That's the box that controls interior dome lighting and also your auto tinting mirror. Sometimes you'll notice that your lights will come on randomly. There's a bad solder joint on one of the components that is easily fixed. Remove the box from the holder it's on, if not just break it off- the holder should be plastic. Disconnect the box from the plug and clean it off with some air. If you're solder capable look on the back or bottom for a joint that looks like it has come off a bit and give it a touch of solder. That will fix your problem. Trust me!!! I literaly tore my car apart trying to find that module. It's also located up near the headlight switch next to some red relays. That's it.
  10. #9
    R-Caddy's Avatar
    Jul 2005
    Savannah, GA
    32
    698
    I think he already tried the Multifunction Module...
  11. #10
    Nov 2008
    29
    29
    yes r-caddy is correct i put a new multifunction relay in it already which fixed a few of my other problems but not my interior lights.. its funny that he mentioned the auto-dimming mirror because that doesnt work in my car either..
  12. #11
    xanax06's Avatar
    xanax06 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Catera
    Jan 2008
    Philadelphia
    144
    Same here, no interior lights, fuses are all good. Anyone know if the light system is a closed circuit type thing, if one bulb is blown they all stop working?
  13. #12
    USEDCAT is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2001
    May 2005
    66
    343
    Quote Originally Posted by xanax06 View Post
    Take the BCM out and re-solder and check again before putting everything back.
    Good luck.
  14. #13
    xanax06's Avatar
    Jan 2008
    Philadelphia
    144
    Quote Originally Posted by USEDCAT View Post
    Good luck.
    BCM? Is that what eastsidercaddy is talking about?
  15. #14
    May 2005
    66
    343
    Probably but I assume you mean R-Caddy. Very poor solder work on these modules.
    Cheers.
  16. #15
    xanax06's Avatar
    Jan 2008
    Philadelphia
    144
    Cheers.
    Alright, I tried what eastsidercaddy posted above. I removed the entire left side
    paneling, took the headlight unit out. removed the A/C vent. I still could barely touch the relay with my finger tip. I should have taken pics, wish I had now.
    So I'm not even sure if I found the BCM.
  • You may not post replies
