service manual
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, service manual in Past Cadillac Vehicle Discussion; Is there a service manual on CD available for the Catera? If so, where could I purchase one?...
    valle1018 is offline Cadillac Owners Member
    Jul 2004
    49
    Lightbulbservice manual
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: service manual
    Since there is no Catera only CD from what i can see, your getting a CD that has all models from GM (what it looks like)
    Jul 2004
    49
    Re: service manual
    I went to the link that you sent but I didn't notice any of them being a CD. Did you find one that was a CD?
    I am trying to figure out what the easiest way to remove my oil cooler oil lines would be. Any ideas or suggestions?
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: service manual
    Here are some pictures, maybe the'll help:
    (this is a write up done about getting to, and resealing the oil cooler- should solve your problems) http://www.cadillacforums.com/forums...achmentid=2888
    http://f6.grp.yahoofs.com/v1/AKr2QGf...%20%26%20Heads
    http://f6.grp.yahoofs.com/v1/AKr2QLO...%20Feed%20Line
    http://f4.grp.yahoofs.com/v1/AKr2QGG...20Feed%20Lines
    Jul 2004
    49
    Re: service manual
    Thanks for the links. I need to see how I can completely remove the oil lines
    so that I can inspect them for leaks. Any suggestions on that?
    Vesicant's Avatar
    Nov 2003
    Jacksonville, FL
    2,703
    Re: service manual
    That write up tells you how.. the lines run near the oil filter.. driver side, put the car up on jacks with the wheels turned fully to the right.. the filter's near the firewall on the driver side of the engine.
  10. Remove Advertisements
