Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: Uneven tire wear on '99 Catera
  #16 (permalink)
Old 08-29-09, 10:39 PM
elvin315's Avatar
Cadillac Owners Enthusiast
Cadillac(s): Platinum 2001 Cadillac Catera Sport
View elvin315's Photo Album
Casino Cash: $12151
Re: Uneven tire wear on '99 Catera
Glad to help. One thing though. If you ordered the once you linked to ebay they'll fit but they aren't adjustable. If that was your intention then OK. But since you mentioned adjustable in your previous post I just thought I'd mention it. Keep us updated. I think I sent you this list before but here it comes again. If the bushings are adjustable I've noted it in the description.
Omega Trailing Arm Bushings
Whiteline Rear Suspension Bushing: part # KCA384 (POLYURETHANE/eccentric) rear outer position only
http://www.globalperformanceparts.co...ons/KCA384.pdf
Provides a camber adjustment range of +/-1.0 degree from base settings for lowered rear suspension (outer position only).
SuperPro Rear IRS Adjusting Kit Camber & Toe Bushing (POLYURETHANE) #SPF0877K
http://www.fulcrumsuspensions.com.au/fulcrumCat/
http://www.superpro.com.au/download/4381.link (PDF)
http://www.fulcrumsuspensions.com.au...mg.php?id=1107
Provides camber and toe adjustment range of +/-1.0 degree over base settings for lowered rear suspension (set of 4 / inner & outer)
SuperPro Rear IRS Control Arm Adjusting Kit (POLYURETHANE): #SPF0877TK
http://www.fulcrumsuspensions.com.au...mg.php?id=1211
(set of 2) Toe adjustment only
SuperPro Rear IRS Control Arm Bushing Kit (POLYURETHANE): #SPF0611K
http://www.fulcrumsuspensions.com.au...mg.php?id=2429
(set of 2) No Adjustments
GTO Trailing Arm Bushings
Pedders Suspensions - GTO IRS Bushing (POLYURETHANE)
GTO IRS Inner Lower Arm Urethane Bush (no adjustments) #EP7023
http://www.peddersusa.com/Solution_GTO.htm
http://wretchedmotorsports.com/image...23_800x533.jpg
Pedders Suspensions - Rear Camber Eccentric (POLYURETHANE)
GTO Rear Camber Kit #5403 (adjustable camber)
http://www.peddersusa.com/images/Ped...mages/5403.gif
http://wretchedmotorsports.com/images/5403_800x533.jpg
SLP Performance: Rear Camber Kit (inner & outer) (POLYURETHANE)
2004-06 GTO: #847-70027 (use w/ #70026 lowering springs)
http://www.jegs.com/i/SLP/847/70027/10002/-1
http://www.jegs.com/images/photos/800/847/847-70027.jpg
Energy Suspension:
GTO Rear Control Arm Bushings: 33188R Control Arm Bushings (POLYURETHANE)
http://www.sfxperformance.com/parts/ENE33188R.htm
Tags: , ,
catera, tire, uneven, wear
