Fog Lights
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, Fog Lights in Past Cadillac Vehicle Discussion; How the hell do i get these out? The front end spent some time under water and my right fog ...
    Southern-Hospitality is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Sep 2008
    117
    Fog Lights
    How the hell do i get these out? The front end spent some time under water and my right fog light went out, I've decided I'm going to fix it now aha.
    Pictures or an explanation would be great.
    iiF3LiXii is offline Cadillac Owners Member
    Automobile(s): 1999 Catera Sport
    Jan 2009
    Connecticut
    32
    37
    Re: Fog Lights
    Ya got to get under the car man!! Haha! There is some brackets securing the assembly to the bumper cover. If ya cant find it under there bring it to a shop. Its a lot easier on a lift. Like anything els.
    Sep 2008
    117
    Re: Fog Lights
    Yea it's a tight squeeze which is why I have had a hard time figuring out how the whole thing comes out.
    Is there anything the water might have done other than just burn the bulb out?
    Jan 2009
    Connecticut
    32
    37
    Re: Fog Lights
    blow a fuse, but i doubt it.
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Fog Lights
    if you're just changing out the bulb then you can just kind of slide right under the car (glasses might be smart) and full a rubber boot of the bottom of the assembly (the one on the inside of the assembly) and swap out the bulb. the assembly has like three screws holding it on and two wires that fit into the backside of it. one screw connects to the lower air dam, one to the far "outside" side of the assem, and one on the lower half i believe. this is all from memory, i believe the bulb is an H3.
    Jun 2007
    Mooresville, IN
    26
    677
    Re: Fog Lights
    you might also have (want) to clean some corrosion off the "hook" or "clip" that holds the bulb in, it's the ground connection and it doesn't always make perfect contact.
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    Re: Fog Lights
    Remove clean reainstall however I think your reflecting surfaces are screwed up... and you will be better off getting a new one... or one out of a junk yard... the ones around here are full of Catera Parts...
    Sep 2008
    117
    Re: Fog Lights
    The reflectors actually aren't bad, I have the bulb I am just waiting till this insane -20 weather goes away.
  11. Remove Advertisements
