| Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron. | Cadillac Forums: Transmission Control Module Replacement
01-05-09, 11:49 AM
| | Cadillac Owners Member Cadillac(s): Catera | | | | | Transmission Control Module Replacement Hello folks.
I am looking to replace the TCM on my 99 Catera. Symptoms are slipping transmission, slow to change gears, power steering is hard.
I found the part on eBay and I need to know if the TCM has to reprogrammed when put in my Catera.
Any help here is truly welcome.
Eric |
01-05-09, 05:41 PM
| | Cadillac Owners Member Cadillac(s): 59,60,73,2000sts,1999omega/catera | | Join Date: Feb 2008 Location: melksham,england | | | Re: Transmission Control Module Replacement no offence intended to this forum but before you purchase said item just try your luck here http://www.omegaowners.com/forum/YaBB.pl
omega,catera,opel 99% identical under the skin  |
01-05-09, 08:54 PM
| | Cadillac Owners Member Cadillac(s): Catera | | | | | Re: Transmission Control Module Replacement Thanks, mate. I checked out the Omega forums, but couldnt get any answers. I need to know if anyone out there has replaced a TCM and if there is a step by step guide online anywhere which could help.
Like always, any help here is certainly appreciated.
Eric |
01-06-09, 04:04 PM
| | Cadillac Owners Member Cadillac(s): 59,60,73,2000sts,1999omega/catera | | Join Date: Feb 2008 Location: melksham,england | | | Re: Transmission Control Module Replacement well i posted a question on the omegaowners on your behalf and im convinced that you have two issues here the tranny and a probably dodgy p/steering pump.when the transmission fluid was changed was there any "debris"in the front sump? http://www.omegaowners.com/forum/YaBB.pl?num=1231262661 |
01-10-09, 12:15 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Sep 2008 Age: 39 | | | Re: Transmission Control Module Replacement I have a brand new tcm for a 99 bought it because i had the same problems with my 98 got it and it didnt fit they are easy to change and i will sell it to you for 50 bucks plus shipping. It is easy to change it is on the passenger side under the kick panel you have to reach up after you remove the kick panel there are 2 bolts you loosen the you have to pull the tcm down un plug it and plug the new one in it takes about 20 min.
01-12-09, 09:18 PM
| | Cadillac Owners Member Cadillac(s): 1999 Catera Sport | | Join Date: Jan 2009 Location: Connecticut Age: 25 | | Re: Transmission Control Module Replacement Hey, I came across a TSB today which included symptoms like slipping trans, late shift or no shift. I have a feeling this might be your problem. The correction talked about taking apart the valve body to clean out solenoids and 2-3 valves. Ill copy and paste the TSB for ya when i get to work tomorrow. GOOD LUCK!! |
01-13-09, 12:55 PM
| | Cadillac Owners Member Cadillac(s): 1999 Catera Sport | | Join Date: Jan 2009 Location: Connecticut Age: 25 | | | Re: Transmission Control Module Replacement TECHNICAL SERVICE BULLETIN
Reference Number(s): 01-07-30-038D, Date of Issue: September 12, 2006
Affected Model(s): 2007 and Prior GM Passenger Cars and Light Duty Trucks; 2003-2007 HUMMER H2; 2006-2007 HUMMER H3; 2005-2007 Saab 9-7X; with 4L60-E/4L65-E/4L70-E Automatic Transmission (RPOs M30/M32/M70)
Supercedes: This bulletin is being revised to add the 2007 model year and the 4L70-E transmission. Also, information has been added to Condition, Cause and Correction. Please discard Corporate Bulletin Number 01-07-30-038C (Section 07 - Transmission/Transaxle).
Related Ref Number(s): 01-07-30-038, 01-07-30-038A, 01-07-30-038B, 01-07-30-038C, 01-07-30-038D
ARTICLE BEGINNING
Condition
Some customers may comment on any of the following conditions:
An illuminated MIL where DTC P0757 is found as a history code in the PCM or TCM.
No 3rd and 4th gear.
The transmission does not shift correctly.
The transmission feels like it shifts to Neutral or a loss of drive occurs.
The vehicle free wheels above 48 km/h (30 mph). High RPM needed to overcome the free wheeling.
Cause
Fig. 1: Locating Components
Courtesy of GENERAL MOTORS CORP.
This condition may be caused by any of the following:
Chips or debris plugging the bleed orifice of the 2-3 shift solenoid (367). This will cause the transmission to stay in 2nd gear when 3rd gear is commanded and return to 1st gear when 4th gear is commanded.
A 2-3 shift valve (368) or 2-3 shuttle valve (369) that is stuck, restricted and/or hung-up in its bore.
This condition may also be an indication of a damaged 2-4 band or 3-4 clutches. This clutch damage may generate debris causing the 2-3 shift valve line-up to stick in the valve body bore and set DTC P0757.
Correction
Inspect the condition of the transmission fluid for signs of overheat or a burnt odor. If either is noted, the transmission should be disassembled for further investigation and repaired as needed.
Inspect the inside of the oil pan for signs of clutch friction material. A small amount of friction material in the bottom of the pan is normal. If a large amount of clutch material is noted in the fluid or bottom pan, the transmission should be disassembled for further investigation and repaired as needed.
Inspect and clean the 2-3 shift valve (368), the 2-3 shuttle valve (369) and the valve bore of debris/metal chips.
Inspect and clean the 2-3 shift solenoid (367B) opening of debris/metal chips. While inspecting the 2-3 shift solenoid (367B), look for a screen over the solenoid opening. If the solenoid DOES NOT have a screen, replace the solenoid. All current GMSPO stock shift solenoids have a screen over the solenoid opening.
If clutch debris is found, it is also very important to inspect the pressure control (PC) solenoid valve fluid screens. Clean or replace the PC solenoid as necessary. It is also important to flush and flow check the transmission oil cooler using J 45096. Refer to SI "Automatic Transmission Oil Cooler Flushing and Flow Test" for the procedure. |
01-13-09, 03:22 PM
| | Cadillac Owners Member Cadillac(s): Catera | | | | | Re: Transmission Control Module Replacement Dudes, you are a lifesaver. I needed to know all of this before I started and this help tremendously. Do you have a diagram of what the procedure is in removing and replacing the TCM? |
01-13-09, 03:25 PM
| | Cadillac Owners Member Cadillac(s): Catera | | | | | Re: Transmission Control Module Replacement Thanks DGlad. I already bought one of eBay for $50, but its used. If its no good, I will gladly buy the new one from you. |
01-14-09, 01:01 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Sep 2008 Age: 39 | | | Re: Transmission Control Module Replacement you can call me and i could explain how to change the tcm send me a pm and ill give you my # |
01-20-09, 12:52 AM
| | Cadillac Owners Member Cadillac(s): Catera | | | | | Re: Transmission Control Module Replacement DGlad,
I was wondering if you could write a quick step by step on replacing the TCM. The car is a 99 Catera. I am coaching my son thru this repair and I dont want to miss anything.
Much Appreciated,
Eric |
01-31-09, 07:51 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Transmission Control Module Replacement Do you still have the TCM for sale? |
01-31-09, 08:48 PM
| | Cadillac Owners Member Cadillac(s): Catera | | | | | Re: Transmission Control Module Replacement Yes, I do. I will take $60 for it which includes shipping. Let me know and Ill invoice you thru PayPal. |
02-04-09, 05:30 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Transmission Control Module Replacement I would like to get it but want to verify the number on mine first. Can you tell me how to find it? |
03-19-09, 02:19 PM
| | Cadillac Owners Member Cadillac(s): 2000 Cadillac Catera | | Join Date: Mar 2009 Age: 27 | | Re: Transmission Control Module Replacement So I know where the TCM (transmission control module) is located on the '99 Catera, but on my 2000 Catera, the air filter component is in the place where the TCM is at on the '99... Anyone know where it might be on the 2000 Catera?
Please let me know!
702-290-4485
Jason athomeprojasons@aol.com | | Cadillac Discussion Tools | | |
Censor is ON | | | |
