Help Me Jack This Cat!!
Results 1 to 11 of 11
Cadillac Catera and Cimarron Forum Discussion, Help Me Jack This Cat!! in Past Cadillac Vehicle Discussion; I have had this 2000 Catera for a few months now-My old ride was a Minivan Still have it but ...
    jjhammer is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    54
    CoolHelp Me Jack This Cat!!
    I have had this 2000 Catera for a few months now-My old ride was a Minivan Still have it but would like to drive the Cat More! My problem is that the Cat sits low and it hurts to get in the vehicle-my one knee is bad. Anyway I was wondering what would be the easiset and cheapest way to raise this cat up about two inches? I don't want to spend a lot of money on the suspension and springs. I also do not want to create any problems with the ride by doing this. Any and all ideas are greatly appreciated!! Thanks!
    Southern-Hospitality is offline Cadillac Owners Fanatic
    Sep 2008
    117
    Re: Help Me Jack This Cat!!
    With what you mentioned, there is not way to do this without compromising the ride or spending good money of springs. It's a low car, you should buy a deville
    whosazso's Avatar
    whosazso is offline Cadillac Owners Member
    Automobile(s): 99 Catera
    Dec 2008
    14
    I too have a problem getting in. However, the Catera has a tilt steering wheel. I don't need it in the "up" position to get out but I put it up anyway because when I go to get in, I grab the wheel and use it to lower myself into the seat.
    This keeps me from sliding down the door post which has a HEAVY rubber seal. Because it's rubber, the slide is awkward and I figure it's no good on my clothes or the door trim.
    Perhaps the tilt steering wheel will assist you too either that or the handle at the top of the door frame.
    Sep 2008
    117
    It was aimed at a younger generation. Perhaps you're already grown out of this generation?
    Oct 2008
    54
    CoolRe: Help Me Jack This Cat!!
    Well, over the years I have grown quite a bit! From a svelte 160lbs to 200. Maybe if I lost weight? LOL Like that will happen! anyway my one leg-knee gives me problems which makes getting into a car low to the ground painful. Maybe I will check into an Allante-Not sure how much higher they are. Otherwise I might look into replacing the springs and such to raise it just a hair. Thanks for the info!!
    billc83's Avatar
    billc83 is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 Allante, 1999 Deville Concours
    Nov 2008
    Seattle, WA
    33
    1,227
    jjhammer -
    As a proud owner of an Allante, I can tell you that the seating position is low! I can't compare it to the Catera, but I'd bet money the seating position is as low or lower.
    I'd second Southern-Hospitality's idea, unless you want to throw in some hydraulics. A Deville might be right up your alley. If your knees are like twigs, pass on the Caddy that zigs!
    Sep 2008
    117
    In my experience the Allante is a little lower (being the sportier car)
    But you can pick up a very nice 2000 and up deville with low K for less than $10,000. And the deville is THE cadillac.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Why not mount taller tires? That or trade for a used STS?
    gunther1000 is offline Cadillac Owners Fanatic
    Mar 2008
    Nashville
    183
    Ya, put some 26" Ghetto hoppers on it. That should bring you up to speed with the "cool Kid" generation... Shees.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    I didn't mean larger wheels. I mean tires with taller sidewalls. The Catera uses a 225/55-16 as standard (the Sport uses 235/45-17). A tire with a 65 to 75 aspect ratio might lift the ride height to suit you better but with a sacrifice in handling due to the more pliant sidewalls.
    Oct 2008
    54
    Thanks for all the suggestions. I have adjusted my seat and have a lot less trouble now. Probably just getting used to getting into a car again after driving in a Minivan for the past 8 years. What a difference in height when I drive the Minivan! Thanks Again!
  14. Remove Advertisements
