Electrical! FOG Light turning off?
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, Electrical! FOG Light turning off? in Past Cadillac Vehicle Discussion; I just resently noticed that my fog lights would turn off after a few minutes of being on... Has anyone ...
    CateraMV6's Avatar
    CateraMV6 is offline Cadillac Owners Connoisseur
    Automobile(s): Opel Omega
    Oct 2006
    Dearborn MI
    1,419
    QuestionElectrical! FOG Light turning off?
    Has anyone else seen this kind of issue? I turn them on and 2-3min later they turn off.. and if you wait lets say 15 min you can turn them back on and they will light up again... and go out in 2-3 min... seems like something is heating up somewhere and shutting off to prevent damage? Any ideas?
    Cadi Cat is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera
    May 2005
    Michigan
    32
    314
    Re: Electrical! FOG Light turning off?
    Have you checked the multifunction switch? Mine did that when the solder joint cracked. The joints expand and contract with heat and cooling. Maybe something you might want to check.
    CateraMV6's Avatar
    Oct 2006
    Dearborn MI
    1,419
    I thought you did a how to on that with some pictures, would you mind sending that link to me so I can take a look at the issue?
    Thanks man. This weekend I will be doing a High Beam/DRL HID conversion with Relay and D2S bulbs with H7 adapters, and I will have a how to early next week....
    lakesidepark is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Catera
    Apr 2006
    Nashville TN
    172
    I had the same problem and the same fix (cold solder joint). I'm pretty skilled with the solder gun so I just went thru and re-soldered any connection on the back of the multifunction module PC board that looked suspect. No problems since (and much cheaper than an $87.99 replacement).
    May 2005
    Michigan
    32
    314
    Here's the link
    http://www.cadillacforums.com/forums...roblems-2.html
    It's a really easy fix. Getting to it is the only hard part but not too bad. Beats whatever the dealer charges.
    CateraMV6's Avatar
    Oct 2006
    Dearborn MI
    1,419
    TalkingRe: Electrical! FOG Light turning off?
    Issue FIXED! it was the K34 Switch as described in one of the posts on here... there was a solder that had cracked and the thing was heating up like crazy... so I resoldered everything and it works like a charm now!
  9. Remove Advertisements
