Funky heater problem
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, Funky heater problem in Past Cadillac Vehicle Discussion; I just replaced my heater control valve following the excellent advice I found on this forum after my cat started ...
    graphicsman is offline Cadillac Owners Member
    Automobile(s): 1999 Catera
    Jun 2006
    57
    I just replaced my heater control valve following the excellent advice I found on this forum after my cat started dumping fluid down the back passenger side of the engine. Thanks!
    However, I know have an odd heater problem. I get no heat, even if I set temp to max. However, if I turn the temp all the way down and then quickly to something like 78F, I get heat just fine. Any thoughts? All the lines look okay and I'm pretty darn sure I put everything on in the right position.
    frank moran is offline Cadillac Owners Fanatic
    Automobile(s): Catera, ..
    Jan 2007
    canton,ga.
    72
    231
    Re: Funky heater problem
    You may have the hoses on the wrong ports, switch the hoses and you should be OK. I know from experience, I just did this repair and I put them on incorretly.
    Quote Originally Posted by graphicsman View Post
