needs brakes light
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, needs brakes light in Past Cadillac Vehicle Discussion; After i put new front ane rear pads on the 99' Catera i see that the orange need brake light ...
    BlackonBlackCatera is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    23
    needs brakes light
    After i put new front ane rear pads on the 99' Catera i see that the orange need brake light is on, i believe i broke atleast 1 of those old and fragile sensors and now im trying to figure how to get that light off. thanks
    Jan 2007
    23
    Re: needs brakes light
    anyone???
    hvy
    hvy is offline Cadillac Owners Member
    Oct 2008
    13
    Quote Originally Posted by BlackonBlackCatera View Post
    If you really don't need the dash warning light, you can put a small jumper wire connecting the two terminals where the sensor switch plugs in on the inside of the wheel and this will make your dash light go out. The system works on a closed loop and when your pads wear out, the sensor wears down and breaks the loop causing the dash warning light to come on. Basically, you are eliminating the warning devices which are only available at a Caddy dealer and definitely aren't cheap.
    Army_MP_From_MO's Avatar
    Army_MP_From_MO is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac
    Mar 2008
    El Paso, Texas, United States
    45
    240
    take the bulb out
  7. Remove Advertisements
